Mu-TH-UR Computer 6000
Goto page Previous  1, 2, 3, 4 ... 16, 17, 18  Next
Mike Rush
PostPosted: Wed Aug 12, 2009 8:24 am    Post subject: Reply with quote
Please excuse the big image but I wanted it to be as clear as possible. These are my 'rotated' versions of the original, angled, key photos, front and back.
At first it's a big mess, but you soon start to see things emerge. I've marked some of the more obvious(?) ones. (I also marked the screw holes because they could be mistaken for objects!)
At the bottom are the six main 'mystery' parts. Some of them are used once, some several times. So... any clues?
Is A the guts of a potentiometer? E looks like a brass strip, possibly a spring contact for something? B, I don't know but there's lots of them.
I forgot to mark at least two transistors (silver cans, far right).
The rest of it consists mostly of odd little metal strips and those pink plastic scraps. Confused
Okay people, let's go! Wink
Does anyone have any experience embedding things in plastic? I've never tried it but presumably this would have been done in several stages:
1) pour thin layer
2) position first components and pour another layer, let dry
3) position more components, pour layer, let dry
4) pour final layer
... or am I way off?
Mike
stephen210
PostPosted: Wed Aug 12, 2009 8:51 am    Post subject: Reply with quote
that is how I would do it. I don't know of any other way...
Mike you are kicking butt!!!
Kevin
PostPosted: Wed Aug 12, 2009 9:11 am    Post subject: Reply with quote
As far as I can make out, the objects are all on one layer. Just placed on top of each other.
Walk tall, walk straight
and look the World right in the eye.
superjedi
PostPosted: Wed Aug 12, 2009 12:38 pm    Post subject: Reply with quote
Would the objects you labeled as diodes be resistors instead? They appear to have the fine color stripes like resistors have.
Mike Rush
PostPosted: Wed Aug 12, 2009 1:34 pm    Post subject: Reply with quote
Yeah, I initially thought resistors too. But then I noticed the black stripe at one end; diodes have this to show which end is the cathode.
So I think instead of various stripes, it might be one stripe and some characters?
To be honest it could be either. Wink
Mike
superjedi
PostPosted: Wed Aug 12, 2009 8:33 pm    Post subject: Reply with quote
Ah! Gotcha.
Could those 2 square objects which are sort of teal in the left pic and reddish/silver in the right pic be transistors?
Mark Sheppard
PostPosted: Wed Aug 12, 2009 9:17 pm    Post subject: Reply with quote
If I can get ahold of these old tv parts somehow.. (we dont have those parts here in US, I can make it no problem for you..
PostPosted: Thu Aug 13, 2009 7:44 am    Post subject: Reply with quote
Yes Mike, good work/research so far...layering is the way to go with the pieces; that's the only way to go as far as I know.
PostPosted: Thu Aug 13, 2009 12:29 pm    Post subject: Reply with quote
I just dug through my box of vintage electron parts and did not find a single match. I will keep looking though.
Mark Sheppard
PostPosted: Thu Aug 13, 2009 8:47 pm    Post subject: Reply with quote
check out GEC semiconductor... (they are no longer around, is was the UK's largest company years ago. I think that is where a lot of this stuff comes from looks maybe like GET transistors and heat sinks.
Mike Rush
PostPosted: Mon Aug 17, 2009 6:55 am    Post subject: Reply with quote
Great - can you be more specific about which parts might be GEC transistors and which heat sinks? Maybe referring to my diagram above?
Back at the box... I went out and found some self-tappers with the right sized head. I used a Dremel to cut the heads off since they don't have to be functional.
They just pop in the holes... but I'll probably superglue them in anyway.
I think technically these might be 'Posidrive' rather than 'Philips', but it's close enough for me! Wink
Still no idea what to use for those other, 'flat', fixings. Confused
Mike
stephen210
PostPosted: Mon Aug 17, 2009 7:23 am    Post subject: Reply with quote
nice Mike.. Nice.
Mark Sheppard
PostPosted: Mon Aug 17, 2009 12:07 pm    Post subject: Reply with quote
GEC-marconi GET 105 UH heat sink it looks like If I am seeing it right..
I can probably identify the rest of the stuff with time. need to find a 1960's era UK television of VHF transceiver box... found one on ebay.co.uk
Mike Rush
PostPosted: Mon Aug 17, 2009 1:57 pm    Post subject: Reply with quote
How much is it going for? I mean I don't want to spend a fortune on this thing, but if it's only a few quid please send me the item number!
Mike
Mark Sheppard
PostPosted: Mon Aug 17, 2009 2:13 pm    Post subject: Reply with quote
Thats the problem GEC was bought out by marconi, and then marconi in 2000 went out of business in consumer electronics. There should be tons of vintage 60's era televisions in the UK, just go find some old squat and see if there are some abandoned ones maybe?
Mike Rush
PostPosted: Mon Aug 17, 2009 4:51 pm    Post subject: Reply with quote
Oh, sorry. I thought you said you'd found one on ebay.co.uk. Confused
Mike
Mark Sheppard
PostPosted: Tue Aug 18, 2009 12:22 am    Post subject: Reply with quote
http://www.transparentsound.com/transistors/vintage-transistors/mullard/mullard.htm
http://cgi.ebay.co.uk/1950s-TV-GEC_W0QQitemZ250484254167QQcmdZViewItemQQptZUK_Collectables_RadioTelevision_Telephony_SM?hash=item3a520665d7&_trksid=p3286.c0.m14
This possibly would have most of what you need, including the round part. they actually should be paying you just to get this beast out of their house...
The GEC Tele by the way actually looks late 50's I tired to find the marconi 2 way transceiver but it must be gone..it was basically a marine radio, but this may have more junk you need
I see the copper metal parts labeled "e" look like the contact pulled out of a spring contact switch
Mike Rush
PostPosted: Tue Aug 18, 2009 12:29 pm    Post subject: Reply with quote
Thanks! LOL, 99 pence for that television? Too bad I live nowhere near Abergavenny! Shocked
Meanwhile... I got these - there should be something in here that will open the door!
I also dug these out of my spares box. Two solenoids...
... one of which I should be able to adapt to retract the door lock (if and when I figure that out).
Finally, for the key I ordered some 'half-round' dowel. I needed two sizes. Here's what arrived:
Spot the problem? The left one is fine. The right one is... not what you would call 'half round'. Why the difference? Who knows. But I think it's a bit off. I contacted the company to ask for my money back! Which means I still need to find that second size. Still, the hunt goes on. Wink
Mike
PostPosted: Tue Aug 18, 2009 6:07 pm    Post subject: Reply with quote
It's only call half-round...but when you put 2 together it's not "round" anymore. It's only about esthetics. A real half one like the one on the right of your picture would protrude too much, let's say at the bottom of a plint, or to finish a baseboard, so that's why in the industry they decided to go with...well not a true half.
At the end of the day it's all about size; on a small scale: true half, on a bigger scale: false half
Mike Rush
PostPosted: Wed Aug 19, 2009 5:34 am    Post subject: Reply with quote
Dress it up all you like, it's still a lie! Razz
They should call it 'part round', or 'round segment'... Wink
Mike
Page 3 of 18
