Machined Replacement Barrel
neosporing
PostPosted: Wed Jan 13, 2010 7:05 pm    Post subject: Paypal sent. good luck! Reply with quote
Thanks you so much for doing these!
good luck with the gig!
we'll be looking forward to your return!
neosporing
ironfist
PostPosted: Wed Jan 13, 2010 7:05 pm    Post subject: Reply with quote
Your work is worth the wait.
Just let me know when you got'em and Ill paypal ya.
The other Karl!
mspaw
PostPosted: Wed Jan 13, 2010 7:29 pm    Post subject: Machined Replacement Barrel Reply with quote
Thanks for the support guys, I aim to please.
-Michael
PostPosted: Thu Jan 14, 2010 1:10 am    Post subject: Reply with quote
what is your paypal address?
tain669
PostPosted: Fri Jan 15, 2010 11:01 pm    Post subject: Reply with quote
Could you please put me down on the list for the next batch and will you be making other BR blaster parts in the near future? Thanks.
PostPosted: Mon Jan 18, 2010 10:43 am    Post subject: Reply with quote
Just want to make sure you have me down for a 'second-run' barrel, and say hello to Prince Willy as well - I understand he's in NZ even as we speak.
Thanks,
Barry
PostPosted: Mon Jan 18, 2010 3:22 pm    Post subject: Reply with quote
I trust that mine is on the way?
megagreg
PostPosted: Tue Jan 19, 2010 8:20 pm    Post subject: Reply with quote
I received my batch #2 Barrel today. It's great, awesome, can't say enough good things about it. Great work mspaw!
PostPosted: Sun Jan 24, 2010 12:26 pm    Post subject: Reply with quote
Still waiting..........
mspaw
PostPosted: Mon Jan 25, 2010 5:50 pm    Post subject: machined barrel Reply with quote
Clutch-
Its being sent today so sorry for the delay. Working from half a world away is a bit rough. But you should see it in a few days.
All the best!
-Michael
PostPosted: Tue Jan 26, 2010 9:45 am    Post subject: Reply with quote
Thanks for the update!
neosporing
PostPosted: Sat Feb 06, 2010 2:11 pm    Post subject: Reply with quote
were the completed barrels in the 2nd batch all sent?
just curious, i know you are accross the pacific... i had seen that clutches was sent and was wondering if the rest were.
thanks.
neo
PostPosted: Sat Feb 06, 2010 4:12 pm    Post subject: Reply with quote
Haven't received mine.
neosporing
PostPosted: Tue Feb 09, 2010 1:10 pm    Post subject: Reply with quote
i've received mine but the dimensions for the taper on the barrel seems to have been reversed...
it's beautiful though Smile i know you are in the southern hemisphere, and i'm in no rush.
PostPosted: Tue Feb 09, 2010 3:54 pm    Post subject: Reply with quote
Got mine yesterday. I'm wondering the same thing. I'm also wondering why the post doesn't have the 'U' shape cut out in top so that it rests flush with the barrel?
PostPosted: Tue Feb 09, 2010 5:32 pm    Post subject: Reply with quote
The World COn discovery showed that there is no U shape to it and that it is just a flat post.
So this is the correct version based on the real prop.
PostPosted: Tue Feb 09, 2010 6:57 pm    Post subject: Reply with quote
I was hoping it would be something like that. Thanks for the info! I've felt so intimidated by this build ever since the worldcon discovery. Now, are our barrels incorrect as far as taper at the end? Mine is almost as flat as sid's. I can take a pic of mine if you want.
Also, how are you guys attaching the barrel to the gun frame? My sidkit has a small screw in the 'plug' that fits into the frame. The new barrel has no hole there.
neosporing
PostPosted: Wed Feb 10, 2010 2:29 pm    Post subject: Reply with quote
the cast allen screw will have to be counter bored or milled out. Same with the magazine housing to allow the mspaw screw to fit like the 08 version. Also, the revolver frame needs to be filed down a bit as the taped holes don't line up exactly. i'm hoping that because of the taper issue, mspaw might be able to make the minor adjustments to fit the 06 model. But the adjustments required to make the worldcon barrel fit the 06 model will only make it look better!
don parker machined out a gorgeous bolt for the 06 kit. Here are some of the early pics, as the 06 sidkit is still in the test fitting stage.
http://propsummit.com/viewtopic.php?p=31584#31584
PostPosted: Wed Feb 10, 2010 11:19 pm    Post subject: Reply with quote
Wrong thread for this Neo. This is MSpaw's thread for the barrel.
neosporing
PostPosted: Mon Jul 12, 2010 7:46 am    Post subject: barrel bevel Reply with quote
any news on the reversed taper?
Page 3 of 4
