Matsuo Community Member
Posted: Thu Apr 01, 2010 10:31 pm Post subject: PKD Magnum |
Been a while since I've posted. Figured I'd drop in and share a recent build I did for a buddy of mine.
It ts a Doppelganger PKD Magnum, great kit from Rick as usual.
The build may seem un-remarkable at first but the truth is that this kit came to me already built and painted. It seemed a little worse for wear and the paint was somewhat thick on it obliterating some of the subtle engraving. I had no choice but to completely strip the piece and start over, no small feat in itself.
Also my hatred of glue is legendary so I broke all the bonded joints and replaced them with screws and locator pins.
The grips had a bad offset so I pulled the threaded studs, filled the holes, re drilled and pressed them back in.
The trigger guard was shrunk a bit, I did a bit of fitting and re fitting to make it look right (by my reckoning) and fastened it with screws.
I re wired the LED's and made it so the 'mag' that holds them is held in with a screw.
I drilled and tapped cross pins for the triggers so they would move, I'm still trying to work out a spring loaded mech for them, but theres not a lot of room to work with in there. If for nothing else even if they cant be spring loaded I like to have my triggers float free so they stand less a chance of being broken.
The grips are frosty so short of replacing them theres not a lot I can do.
The colors are worldcon inspired, I wanted it subtle, not too flashy
So here you go... Just so you know I'm not all Pulse Rifles and Galactica blasters.
Thanks for looking hope everyone is well!
Matt |
Posted: Thu Apr 01, 2010 11:04 pm Post subject: Re: PKD Magnum |
Matsuo wrote: |
Matt |
A really perfect build mate. Hard to believe that its not steel. You have done a magnificent job and I'm grateful to you for sharing...
Bravo
Regards
MARK _________________
Posted: Fri Apr 02, 2010 12:37 am Post subject: |
Matt you are a Master. So how much do you charge to build a PKD? That thing is awesome.
Posted: Fri Apr 02, 2010 7:55 am Post subject: |
Thanks!
I buid them so infrequently I never really set a price.
I'll have to think about it.
M |
Posted: Fri Apr 02, 2010 9:32 am Post subject: |
Matt, that is insane!
Love seeing your work.
Neil. |
Nexus6 Community Member
Posted: Fri Apr 02, 2010 9:10 pm Post subject: |
A MASTERFUL job, as usual.  _________________
jfuste Community Member
Posted: Sat Apr 03, 2010 2:20 am Post subject: |
Thinking about sending you my two kits to be mounted and painted so well! Wow!
Great job! _________________
Posted: Sat Apr 03, 2010 10:09 am Post subject: |
That's a sweet build, Matt!
Very very nice. I like it.
K |
Mr_Creepy Community Member
Posted: Sat Apr 03, 2010 10:51 am Post subject: |
Absolutely gorgeous rebuild Matt!  _________________ - Brian (formerly ToothTech)
Posted: Sun Apr 04, 2010 7:29 am Post subject: |
Matt, nobody thought for a sec. that you were a one trick pony (Pulse rifle ). Sharp build, clean line and great paint  |
