Posted: Sun Jul 25, 2010 7:44 am Post subject: |
Good stuff...eager to see the final result, of course it's a labor of love (takes time) and with all those details in the apt... |
Joined: 08 Nov 2009 Posts: 654 Location: Cinco Ranch, TEXAS
Posted: Mon Jul 26, 2010 6:47 am Post subject: |
I love what you've done, using the actual pics and drawing your perspective on them (clever). The chairs in Decks apt. are also difficult to repro...if you need anything, let me know (PM). |
Posted: Mon Jul 26, 2010 11:07 am Post subject: |
the custom coil couch is a b@#ch to see in ANY shot i can find. Need to see the side tables and how they are connected... the coil chair is a bit easier. The argyle chair is easy to draw, but hard to find premade in the correct scale. the1/6 scale ones being too thick. yes, Joberg, i may enlist your skills to walk me thru construction.... your a good man to offer!! |
Posted: Mon Jul 26, 2010 1:18 pm Post subject: |
Anytime I'll see something or have additional info: you'll be the first to know (that or I'll PM you a drawing ). The sofa is the of the same design as the chair (a base with three ribs and then on top is that fold of a long sausage ). |
Posted: Mon Jul 26, 2010 1:49 pm Post subject: |
Yes i have a quick sketch in the FB album... its the side tables lit from blelow that intrique me... they almost look lika raindrop design... although i doubt if anyone would complain if i just MADE them a raindrop... |
Posted: Tue Jul 27, 2010 6:43 am Post subject: |
Teardrop (with fabric and with that particular design) is not easy to make. I don't know what you'll use to repro the sofa, chair and side table but I was thinking Sculpey or other similar medium, and then paint it with a silver colour and add sparkles |
Posted: Tue Jul 27, 2010 11:25 am Post subject: |
Pixi dust, the fine sparkles some women wear on their faces might be small enough to not be noticeable and ruin the illusion of scale. Some pearlescent paints may also work,
Posted: Fri Jul 30, 2010 4:16 am Post subject: |
Liquidtex produce some textured acryllic paints in a variety of finishes some are pearlescent and they do a range of sparkly paints as well ! |
Posted: Fri Jul 30, 2010 8:22 am Post subject: |
Yep, at my store they sell a spray can full of sparkly dust mixed in with a clear mat varnish...easy to use and I believe the sparkles would be in scale with a 12 inche puppet. |
Posted: Mon Aug 02, 2010 2:41 pm Post subject: |
I have a while before i am building the set... want to finish the script and the set floorplans... may be farming out the construction of some essential set pieces to speed progress. But the coil couch and chair will be made from sculpey unless i find an upholestry outlet. |
Posted: Fri Aug 06, 2010 6:40 am Post subject: |
Good idea, I would go with Sculpey as well. The rest of the furniture would be a mix media type of project (wood, plastic, cardboard, metal, etc). |
Posted: Sun Aug 08, 2010 8:52 am Post subject: |
Looking good. Keep on truckin' Ben. |
Posted: Mon Sep 27, 2010 3:16 pm Post subject: |
added some cross section views from the lobby and elevator area... _________________ I've had people walk out on me before, but never when i was being so charming |
Posted: Tue Sep 28, 2010 7:09 am Post subject: |
Glad to see that you're still at it Good thing that you're spending all that time making sure the floor plan is accurate, that'll help you with the actual set...which I'm eager to see. |
Posted: Tue Sep 28, 2010 7:28 am Post subject: |
Yes, kudos Ben, Im still umming and arhhing over my diorama. _________________ Formerly offworld66 |
Posted: Tue Sep 28, 2010 11:18 am Post subject: |
Before going into the BR/Alien prop-repro-dept. I was into the diorama stuff...and I had to stop because of a few things: lack of room (my stuff is always big scale) and the time spent at getting every little details so as to be photographed in the right light (exterior shots mainly) and puzzling people about the real scale (true or dio?). I really admire our friend here and the work he's doing, 'cause it's only going to get more complicated in the future |
Posted: Wed Sep 29, 2010 11:57 am Post subject: |
Thanks for the kind words... we are slowly getting there. Hopefully before 2019. _________________ I've had people walk out on me before, but never when i was being so charming |
