another Blade Runner blaster toy rip-off VERY GOOD!!!
Goto page Previous  1, 2, 3
PostPosted: Mon Jan 10, 2011 8:11 am    Post subject: Reply with quote
Good stuff BVB... Cool
Baron Von Blondle
PostPosted: Mon Jan 10, 2011 7:03 pm    Post subject: Reply with quote
I just have ine question..dumb as it sounds...what's 1/17 of an inch in cm? or maybe put simpler..whats the dimensions of the butt plate in cm? Very Happy
Embarassed
Respect
P.
Illustrator, Propmaker, general fiddler....https://www.facebook.com/Strangelysaucy
PostPosted: Mon Jan 10, 2011 7:46 pm    Post subject: Reply with quote
Do you mean 7/16 of an inch? 1/17 of an inch is not a common measurement for inches which is usually divided in half over and over again..for example 1/2, 1/4, 1/8, 1/16, 1/32, etc. 7/16" is about 12mm, and 1 7/16 is about 37mm. Making the final buttplate about 64mm x 37mm x 12mm.
Baron Von Blondle
PostPosted: Wed Jan 12, 2011 3:01 pm    Post subject: Reply with quote
a little more progress...
With help from some great folks here I've tentatively drafted the frame for the grip. It's potentially a goer in some 1/2" wood but until I've decided on material for the actual grips themselves I'm holding fire on cutting it.
So in the meantime, to not lose momentum/excitement I've been busy with some minor beautification.
The double trigger is an iconic part of the design so I got that sorted fairly easily by cannibalising a trigger from the mini blaster.
They won't function as such but are pretty sturdy against the attack of curious fingers..
My mini pipe cutter arrived today too so I set about cutting down the barrel insert I've already started on..
The issue here is that the pipe is barely 1mm thick so needs to be fattened up somehow to look more badass..two options present themselves now the first is my trusty rubber washers...
or this cheeky little leftover from a mini scope..it has a lens so looks quite cool, if not screen accurate (so what?) not sure which to go for yet though....
With the backup blasters sitting in thier packaging still it struck me that I could cut out the half laser sight on it and also on my hero I'm working on and by carefully sanding and cutting could put the two halves together to create a more 'standout' rod...
and lastly for now, the two halves after a few coats of primer...much better...
Respect
P.
PostPosted: Thu Jan 13, 2011 8:02 am    Post subject: Reply with quote
Looking good! Keep up the good work Wink
Baron Von Blondle
PostPosted: Tue Jan 18, 2011 11:58 am    Post subject: Reply with quote
minor setback...I hope...Applied a testcoat of gloss black on one half of the toy and not only is the gloss really hideous (enamel hobby spray - big mistake) but as I took the masking tape off so off came the gunmetal coat along with primer....doh!
any tips on a gentle way to remove the hideous enamel? thinners and a sponge?
Anyway, so the lesson learned here is...sand first, DON'T use cheap primer and stay away from hobby paints! (I usually use automotive paints to great effect)
Inother news I may have a shipment of the original toys late this week to pass on...fingers crossed for that too
and on...
Respect
P.
IGNITERS
PostPosted: Tue Jan 18, 2011 5:13 pm    Post subject: YIPPEE! Reply with quote
I'd love to get ahold of one of those toys!
Robotprops
PostPosted: Tue Jan 18, 2011 8:00 pm    Post subject: Reply with quote
I would just get at it with 1500 or 2000 grit wet/dry. You can sand out all the runs and get the gloss back with a clear coat.
PostPosted: Wed Jan 19, 2011 1:19 am    Post subject: Reply with quote
The easiest way is to dip it in Pinesol (original pinesol only no Lemon) it will take all the paint off without harming the plastic. Leave completely submerged in covered plastic container for 24-48 hours and then simply wash and scrub off excess under cold water.
Sanding takes forever.
Baron Von Blondle
PostPosted: Wed Jan 19, 2011 7:58 am    Post subject: Reply with quote
I think we call that stuff Dettol over here...cheers..I'll give that a go, don't wanna spend the rest of my life sanding Very Happy I just spent 2 hours sanding the buttstock on my EE-3 now my arms hurt...#
Respect
P.
PostPosted: Wed Jan 19, 2011 9:20 am    Post subject: Reply with quote
I've never stripped paint off thin sheet plastic like that. I've had bad luck with paint removal from plastics. With resin you can use oven cleaner to strip off paint without damaging the resin. It melts plastic though, so be careful the stripper you choose doesn't just turn your thin plastic there into a gob of goo.
If you still have the grips lying around, I'd test the paint remover on those first to make sure it doesn't destroy the material.
Good luck to you!
PostPosted: Wed Jan 19, 2011 4:39 pm    Post subject: Reply with quote
Non acetone nail polish remover also works, and it wont melt plastic.
PostPosted: Wed Jan 19, 2011 4:54 pm    Post subject: Reply with quote
Since you have some pieces you cut off you can use them for tests. I have heard oven cleaner will work for this too, but the plastic you have looks to be styrene, and may melt with just about anything.
PostPosted: Wed Jan 19, 2011 7:36 pm    Post subject: Reply with quote
Pine sol (original) is 100% safe on plastic.
Non Acetone remover takes too long
Oven cleaner does not always get every nook and cranny and is very very toxic.
Baron Von Blondle
PostPosted: Sun Mar 06, 2011 8:11 am    Post subject: Reply with quote
well..the news is bleak for acquiring more of these toys...the shop that previously stocked the toys no longer has them. there are a number of similar stores around town that I'll try today but if that draws a blank then we're in trouble.
The toys themselves have no indication as to who manufactered them apart from the Spanish distro who refused to help as I am not a: Spanish nor b: A store willing to buy a ton of boxes, they couldn't even confirm if they had the toy in stock or not...
I do have a telephone number from them tho of a small family run shop in Barcelona who might have some...maybe I dreamed the whole thing? did I really find these toys? am I really here?....
Respect
P.
OUTLAW
PostPosted: Sun Mar 06, 2011 11:13 am    Post subject: Reply with quote
Hi,
I live an hours drive from Barcelona and also speak Spanish, I´d bo more than happy to check this out if you want me too.
Also searching for BR toys but not this one, I´ve got a few of the other type with lights and sounds, made in china but bought in the UK. Searching for a snub toy.
PostPosted: Mon Mar 07, 2011 4:05 am    Post subject: Reply with quote
OUTLAW wrote:
Hi,
I'd be interested in one of these if you could find one in Spain.
Page 3 of 3
