Nice save? (Pictures fixed)
Robotprops
PostPosted: Thu Feb 03, 2011 3:56 pm    Post subject: Nice save? (Pictures fixed) Reply with quote
You may have seen these kits around. they're a very poor recast of a recast of what I think was a Rick Ross Magnum. It comes as a single lump of resin with grips and triggers to be attached. It was full of bubbles and pitted areas as well as a lot of misshapen lines.
I decided to have a go at it. The grips are actually pretty good, so I'm saving them for a future project. I wanted to try wood grips again anyway. I replaced the grip frame, butt plate and trigger guard with aluminum. I spring loaded the triggers. I replaced the resin nub in the top barrel and replaced it with a metal nozzle from a spray gun. I then replaced every screw and bolt with metal as well as the over-sized binding post.
It's pretty rough, but not bad, I think, considering how much it had to be filled, sculpted, sanded and carved.
PostPosted: Thu Feb 03, 2011 4:56 pm    Post subject: Reply with quote
That looks awesome!
PostPosted: Fri Feb 04, 2011 3:29 am    Post subject: Reply with quote
Brilliant job, especially those grips. The Coolmodels recast is from Rick's PKD-1, not the magnum. The upper reciever is the same as the magnum though.
PostPosted: Fri Feb 04, 2011 5:02 am    Post subject: Reply with quote
Yeah those grips came out really nicely
PostPosted: Fri Feb 04, 2011 8:12 am    Post subject: Reply with quote
From pumpkin to princess! Very good job at transforming a lump of resin into a very decent gun Cool
