Building the Nostromo Emergency Destruction System.Possible?
Goto page Previous  1, 2, 3
PostPosted: Fri Jul 22, 2011 4:57 pm    Post subject: Reply with quote
Thank you mates !
Pro Mod wrote:
As I have a sheet of those orange static warning stickers it shouldn't be too difficult to work out the scale of everything.
That's interesting. What kind of marking are they ? Something used on aircrafts maybe ? Could you please post a scan of them ?
Vader
PostPosted: Fri Jul 22, 2011 5:36 pm    Post subject: Reply with quote
Is it that, what my eyes would call yellow, ESD warning label (CAUTION etc etc) at the bottom of the lid?
Pro Mod
PostPosted: Thu Aug 11, 2011 3:17 am    Post subject: Reply with quote
If you follow the links they will take you to the original stickers used on the illuminated panel and the destruction mechanism.
http://propsummit.com/upload/878/illuminated_panel_antistatic_small_40mm_x_1875mm.jpg
http://propsummit.com/upload/878/illuminated_panel_caution_large_57mm_wide_x_565mm_.jpg
http://propsummit.com/upload/878/illuminated_panel_caution_medium_845mm_x_375mm.jpg
http://propsummit.com/upload/878/caution_large_53mm_x_375mm.jpg
http://propsummit.com/upload/878/caution_small_395mm_x_185mm.jpg
They're scanned from my original warning label sheet which was produced by the art department.
They’re fluorescent orange in colour.
The file names contain the dimensions of the black outer boundary, so it should be quite easy to scale everything from the photographs.
If you look carefully they're used in some of the other sets.
If anybody posts them elsewhere I'd appreciate a mention.
Phil
BR26354
PostPosted: Thu Aug 11, 2011 3:38 am    Post subject: Reply with quote
Phil--outstanding, Thank You! Dammit, I love this website...
Vader
PostPosted: Thu Aug 11, 2011 3:52 am    Post subject: Re: Building the Nostromo Emergency Destruction System.Possi Reply with quote
Brilliant resource, Phil!
But surely, looking at this picture:
offworld66 wrote:
Surely the two large, square British and two small American ESD labels at the top are a different colour than the oblong British label at the bottom?
(Interesting historical information, in those labels: it seems America was using their own warning symbol for ESD back in those days. The one in the British labels has since become the global standard.)
PostPosted: Thu Aug 11, 2011 8:02 am    Post subject: Reply with quote
Excellent Phil, big thanks for these (that's why I love Propsummit Cool )
Pro Mod
PostPosted: Thu Aug 11, 2011 9:04 am    Post subject: Reply with quote
I think the reason for the colour difference is that the lower label was created as part of the original artwork and that after the panel was finished they applied the paper labels when somebody probably commented that it looked a bit bare in the corners.
The reason for the colour difference is that the panel was probably a piece of clear Perspex with the black image screen printed on the rear face, with colour achieved using pieces of lighting gel held in place with tape.
The problem is no gel is that bright and they would have just used the brightest colour available to them.
It’s so much simpler today - design on the computer and have it printed on light diffusing film.
When they say they don’t like it just alter the artwork and print it again. Easy!
Vader
PostPosted: Thu Aug 11, 2011 9:53 am    Post subject: Reply with quote
They still seem to have used the exact artwork inside the frame from the 845x375mm label you posted, though.
I'm thinking though that the orange background of the four upper corner labels is the odd one out in this context. The yellow background is what you'd usually find in these labels — just look here, for instance.
Question is however, were these labels found items, or did the production just screen print found artwork?
- If the former, one wonders if not both background colors would have been available on stickers even at the time.
- If the latter, one wonders why? Why not create "in-world" artwork, instead of going through the trouble of reproducing artwork that is totally out of context...
Bearing in mind that the yellow background seems to be an exact match for the yellow text, just like the orange backgrounds are an exact match for the orange text, wouldn't it seem likely that both colours were done the same way; either as stickers or with gels?
I do wonder though if it actually was a Perspex panel, and not just opaque artwork on a solid surface... It seems to me that the panel is not back lit, but rather just lit by the recessed lights on four sides: notice how the surface, regardless of whether it is black or has artwork on it, is brightest closest to the edges, and how the illumination falls off towards the centre, or where the edge lights do not reach (like the small American labels on top).
Pro Mod
PostPosted: Thu Aug 11, 2011 11:53 am    Post subject: Reply with quote
The labels they used were definitely printed for the production.
They're on a sheet size 227mm x 177mm and there are ten different labels.
The ones you buy today (and probably back then) are sold in rolls of individual labels.
There's also quite a lot of the sheet which isn't printed.
I'm assuming they used some of this to produce the arrows around the equipment in the tray.
Regarding the colour, it may be that they didn't have a self adhesive label sheet in yellow or that they were considered just too bright to be scattered about the sets.
Sadly I don’t think we'll ever know.
I hate to admit it but I think your right about the panel not being back lit.
I've always been convinced it was.
http://propsummit.com/upload/878/nostromodestruct.jpg
The colours are quite noticeable which is something that wouldn't happen without illumination.
Also, the panel is set quite far back into the lid which means there wouldn't be enough room for the fluorescent tubes.
I'm glad I didn't spend any money on producing an illuminated panel!
PostPosted: Fri Aug 12, 2011 7:54 am    Post subject: Reply with quote
Yes, the neon tubes on the sides of the lid might give the false impression that the panel was back-lited...no such thing as you, and others have discovered along the years.
PostPosted: Thu Aug 25, 2011 10:55 am    Post subject: Reply with quote
Incredible pics, thanks very much Fred and SJ and thanks for the graphics Phil.
Havent done much on this project for a while but my slow times coming up and hope to fire up again, has great potential this project.
Neon on the inside of the lid, fascinating.
PostPosted: Fri Aug 26, 2011 2:58 pm    Post subject: Reply with quote
Tim !
Glad to see you back mate !!!
Can't wait to see what you're going to do with these new infos and references !!!
PostPosted: Sun Aug 28, 2011 5:43 am    Post subject: Reply with quote
Thanks Fred.
Page 3 of 3
