Ki-Djowac Community Member
Posted: Sun Nov 18, 2012 3:11 pm Post subject: |
So, we're there
How i intend to display it once i made some room in my cabinet :
There you have it |
Posted: Mon Nov 19, 2012 7:40 am Post subject: |
A+ Ki-Djowac...but I think it's rather problematic to display it with a picture of Jessica; what to look at first? |
Posted: Mon Nov 19, 2012 9:56 am Post subject: |
True indeed
Imagine the conversations :
Dude : 'Hey, that's just beautiful, amazing and kick ass dude'.
Me : Yeah, but what do you think of the gun ?
Posted: Mon Nov 19, 2012 7:12 pm Post subject: |
Posted: Sun Dec 09, 2012 5:59 am Post subject: |
One last update :
After watching the Blu-Ray i noticed something else on the gun. Red safety dots. The Umarex Beretta doesn't have these.
Yeah, somehow, when you did a prop from a movie, you watch the movie differently then before
Anyways, here's my last adjustment :
I recommend using a size zero paint brush for painting the red dots and a 3mm drill for drilling the dent on one side. When looking very closely at the Umarex Beretta 90two you'll notice that there's a obvious dent on one side and a very light circular marking on where the dent should have been. This is the place to drill. The slide is metal so primer first and then i picked up a model paint ferrari red (n° 34) from Revell.
And finally done :
Posted: Sun Dec 09, 2012 9:05 am Post subject: |
The devil is in the details and you certainly produced a kick-ass repro Ki-Djowac...very cool |
Posted: Thu Dec 13, 2012 1:21 am Post subject: |
Thx for the compliment Joberg.
Gonna start the run for these very soon. _________________
Posted: Tue Dec 25, 2012 4:08 pm Post subject: |
Allright y'all,
inspired by Bad Wolf over at RPF i got my own 6mm Beretta 90two springer gun.
As Bad Wolf pointed out, the two guns look indentical, but still there are small differences in measurements between the two which leaves a small gap between the front barrel slide and compensator itself.
I modified 2 pieces on the springer gun : i filed about 2mm on the front of the weaver rail and dremelled the trigger guard. On the front weaver rail mod i locked the barrel slide as if it was empty and used some masking tape to avoid damaging the plastic cilinder/barrel parts.
The other modifications were done to the compensator itself where it was drilled in front where the cilinder part right beneath the barrel would go on the inside and some dremmeling where the trigger guard would fit against the compensator.
First fit :
And some close ups of the 2 modifications on the springer :
After the trigger guard was dremelled, i used some sanding paper to try and match the factory finish of the plastic again. I used the following grids of sanding paper : 400 - 600 - 800 - 1000 - 1200 and finally a 15 micron 3M polishing paper. Anything higher then the 15 micron proved that the finish became too shiny compared to the rest of the gun.
Primer and sanding on the springer compensator is done and i'll start layering matt black soon _________________
Posted: Fri Dec 28, 2012 4:43 pm Post subject: |
Good stuff again Ki-Djowac... |
Posted: Fri Dec 28, 2012 5:54 pm Post subject: |
Thx Joberg
The springer comp is done, but i'm gonna finish my co2 comp first so i can do a comparison pic. Should be by the end of the weekend. _________________
Posted: Tue Jan 08, 2013 4:29 pm Post subject: |
Last but not least : a comparison between the 2 modified finished versions. Springer vs CO2 : Spot the difference
That's it y'all. Done ! _________________
Posted: Tue Jan 08, 2013 6:27 pm Post subject: |
Very good transfo for sure! Did you shoot the weapons already and if so, how is the add-on reacts? (like in the film I suppose?) |
gomcse Community Member
Posted: Wed Apr 02, 2014 6:20 pm Post subject: |
Wait! What happened??? Did you finish this? It's been almost 2 years!
Dave
resurrecting threads that died. |
Posted: Wed Apr 02, 2014 6:53 pm Post subject: |
I believe he did... |
Posted: Wed Apr 02, 2014 7:01 pm Post subject: |
But...is he selling them....?? What if we want one.....LOL.
Dave |
Posted: Thu Apr 03, 2014 4:09 pm Post subject: |
I know he did a run on the RPF in the JY...you could also check there or sent him a PM here at Propsummit |
