Looking for the Switch
DaveG
PostPosted: Sun Oct 05, 2014 9:25 am    Post subject: Looking for the Switch Reply with quote
Does anyone have a source for the little slide switch on the right side of the clip? Thanks!
Dave
PostPosted: Sun Oct 05, 2014 11:15 am    Post subject: Reply with quote
All I have been able to find is a usable switch with a black button, which I then paint white.
As for the cover with the on/off words I cast mine in the ammo clip.
I do have a older peel and stick label BUT it is a little over sized.
Your not the first to try and find these...if you do I hope you will share the info.
PostPosted: Sun Oct 05, 2014 4:34 pm    Post subject: Reply with quote
Is there any (electronic) info printed on the switch? If I had something more to go on I could probably find some..
PostPosted: Sun Oct 05, 2014 7:46 pm    Post subject: Reply with quote
On the real one no one knows on the Tomenosuke Pro it is buried under hot glue...
On mine it does not really matter as mine is black.
