Tomenosuke Blaster finally finished (pic heavy)
cratercritter
PostPosted: Mon Nov 03, 2014 1:15 am    Post subject: Reply with quote
Well done. Shocked Most impressive blaster finish. So pretty and shiny. Cool
PostPosted: Fri Nov 07, 2014 4:09 am    Post subject: Reply with quote
What a fantastic finish! Thanks for the blueing tips.
stonedog7563
PostPosted: Wed Nov 12, 2014 5:01 am    Post subject: Reply with quote
Thanks all for the kind comments
Added some weathering/wear to the butt plate and grip frame.
PostPosted: Wed Nov 12, 2014 6:11 am    Post subject: Reply with quote
One question, you did the whole model as super clean brand new, why the scuffed butt plate??It too should be like brand new.
stonedog7563
PostPosted: Wed Nov 12, 2014 6:37 am    Post subject: Reply with quote
Thought it resembled this more
PostPosted: Wed Nov 12, 2014 6:45 am    Post subject: Reply with quote
OK That works..and I missed the missing paint above the butt plate on the grip frame..
I stand corrected.
GREAT job by the way.
stonedog7563
PostPosted: Wed Nov 12, 2014 6:55 am    Post subject: Reply with quote
No need, your input is very much appreciated, thank you
PostPosted: Wed Nov 12, 2014 6:58 am    Post subject: Reply with quote
Are you absolutely SURE you want to keep that?? Very Happy
STUNNING!!
PostPosted: Wed Nov 12, 2014 10:23 am    Post subject: Reply with quote
A truly stunning blaster, warmest congratulations!
Highest regards
MARK
PostPosted: Wed Nov 12, 2014 5:00 pm    Post subject: Reply with quote
Love it! And the wear and tear is very well done also Cool
PostPosted: Thu Nov 13, 2014 9:39 am    Post subject: Reply with quote
ok, how'd you weather the plate so nicely? Smile
stonedog7563
PostPosted: Thu Nov 13, 2014 11:31 am    Post subject: Reply with quote
O.k. might sound silly but it took three attempts, I was trying for a similar scratch pattern as seen on the real thing, I know I wasn't going to duplicate it scratch for scratch but I wanted it to resemble it if possible.
Wrapped the sides with masking tape, as close to the edge as possible (don't need to be too precise as most of the paint comes off anyway) keyed the surface with 320 grit paper to give the paint something to hold onto then gave it two light coats of matt black out of a rattle can.
After about an hour or so I removed the masking tape then left it overnight.
Then I cleaned up the edges using some fine paper (1000 grit I think) then gently sanded the flat painted area with 2000 grit to thin and flatten the paint out (all sanding was done dry)
For the bulk of the scratches I used 120 grit, gently scuffing the surface to get general background scratches and wearing the paint away so the metal ghosted through in areas.
For the edges and stand out scratches I just used the blade of a small flat head screwdriver to etch the pattern into the paint.
To finish I gave the whole bottom a very gentle sanding with 5000 grit to flatten it.
Hope that helps.
PostPosted: Thu Nov 13, 2014 4:56 pm    Post subject: Reply with quote
Thanks for the weathering tips!
PostPosted: Fri Nov 14, 2014 11:01 am    Post subject: Reply with quote
excellent. thanks
TomasVolley
PostPosted: Tue Dec 02, 2014 4:37 pm    Post subject: Reply with quote
Absolutely top notch. Best I have seen!
Thanks for great pics.
What about green LEDs. They work too?
stonedog7563
PostPosted: Tue Dec 02, 2014 5:10 pm    Post subject: Reply with quote
Your welcome, thank you for the comment.
Green LED's are not wired so don't work no.
John.
Kalel76
PostPosted: Tue Dec 02, 2014 8:18 pm    Post subject: Reply with quote
Gorgeous.
VFX Freak
PostPosted: Thu Dec 04, 2014 8:14 pm    Post subject: Reply with quote
Wow! That is an absolutely stunning finish. I think it's a fantastic representation of what the gun would have looked like when Deckard first got it. That's what I was going for as well, but I didn't achieve nearly this good a result. Very well done!
"I shoot better when I move." - The Sundance Kid
PostPosted: Fri Dec 05, 2014 11:01 am    Post subject: Reply with quote
Museum Quality indeed. Shocked Shocked Shocked Shocked Shocked
spinner 44
PostPosted: Mon Dec 15, 2014 12:27 pm    Post subject: Re: Blaster finally finished (pic heavy) Reply with quote
stonedog7563 wrote:
Hi all, just finished my pro and thought I would post some pics, I would love to say it was fun, but it wasn't, if I never see a bottle of blue ever again it will be too soon.
Thanks for looking.
John.
I get a picture deleted message.. the rest of you do too?
Page 2 of 3
