metal parts replacement info
Deckard_0489
PostPosted: Sat Oct 24, 2015 10:51 am    Post subject: metal parts replacement info Reply with quote
hi guys, you can tell me where I can find (if is possible) a metal replacement kit for some parts of the blaster (bolt, barrel, cylinder)? thanks
PostPosted: Sat Oct 24, 2015 2:08 pm    Post subject: Reply with quote
It would probably be a good idea the write WHICH blaster you have Wink
Perhaps Mr. Coyle...?
cratercritter
PostPosted: Sat Oct 24, 2015 5:02 pm    Post subject: Reply with quote
Yeah that would be helpful to know... which Blade Runner Blaster you referring to?.... They are all relatively different in tolerances and construction and materials.....
Coyle Blaster, Rick Ross PKD, Sidkit, Offworld Blaster, Takagi Blaster, Tomenosuke Blaster, Elfin Knights ....?? etc.
Deckard_0489
PostPosted: Sat Oct 24, 2015 5:50 pm    Post subject: Reply with quote
I've buy this one: http://www.ebay.it/itm/301757941111
It's Italy manufactured, the gray part are all metal, black part resin I guess, I'd like to replace some of the resin part with metal.
PostPosted: Sun Oct 25, 2015 3:10 am    Post subject: Reply with quote
That looks like a Sid kit reissue..
It still has my 3 screws handle to pistol frame screws.
That is a recast of one of my older plastic models.
Interesting as it is now a mix of pewter and plastic parts.
Price is good and low...my 95% good pewter kits run $600.00
But you will be on your own and as it is a recast and perhaps another recasting of a recast I cannot say it will be able to fit any other parts made by anyone else..
IF you want to see one of my best offerings check out:
http://www.ebay.com/itm/191638182086?ssPageName=STRK:MESOX:IT&_trksid=p3984.m1561.l2649
For a low cost version I would think you would be better off with a Offworld model, they are off but better made.
Deckard_0489
PostPosted: Sun Oct 25, 2015 10:28 am    Post subject: Reply with quote
ok, but I'm not interested to buying another blaster, I already have mine, I wanted to know if I can find some metal replace parts.
