Deckards Blaster 3D print
BladeRunner96
PostPosted: Tue Mar 08, 2016 3:09 am    Post subject: Deckards Blaster 3D print Reply with quote
Hi so ive just 3D printed some parts for my blaster and am machining metal parts to go along with it mainly the frame and the barrel and hopefully the shot gun part on top , does any one know where I can get all the screws and allan key bolts to assemble the gun ?
If any one would be interested in a ABS/cast metal and machined parts then let me know I Can probably do a kit for £180 including display stand
Droids,time machines,Blasters,Hot Rods,Dont cross the streams
PostPosted: Tue Mar 08, 2016 4:43 am    Post subject: Reply with quote
Just curious, can you make metal barrels?
And welcome on board
Pro Mod
PostPosted: Tue Mar 08, 2016 7:45 am    Post subject: Reply with quote
Try this company for fastenings in metric and imperial.
https://www.ekpsupplies.com/
Will you post some photographs of your progress.
PostPosted: Tue Mar 08, 2016 5:12 pm    Post subject: Reply with quote
Welcome and pics when possible Wink
BladeRunner96
PostPosted: Wed Mar 09, 2016 3:33 am    Post subject: Reply with quote
I'll post a couple of pics in the next hour , I can machine a metal barrel and I plan to cast the shot gun barrel that sits above the other barrel out of pewter
BladeRunner96
PostPosted: Thu Mar 10, 2016 1:54 am    Post subject: Reply with quote
Sorry for the delay , it's not put together fully properly yet but it's got around thirty five parts to build it but it will soon have some machined parts for the barrel and handle frame and then the rail will be cast it pewter
Here's two photos of it when first quickly made sure it all fit together most of it all snaps together but you will want to use glue what not to fix it together .
DVD Connoisseur
PostPosted: Thu Mar 10, 2016 3:29 am    Post subject: Reply with quote
Great work. What makes this project so exciting is the fact that it's a blaster build in the UK! Would be very interested to see a snub nosed blaster at some point in the future!
My current grail piece is Leon's 'ickle "real world" pistol. Shouldn't be too difficult to find but a kit would be welcome!
PostPosted: Thu Mar 10, 2016 5:32 pm    Post subject: Reply with quote
Difficult to see the details in the pics; seems like there's a lot of clean-up to do though. (Can we say Acetone Wink )
BladeRunner96
PostPosted: Fri Mar 11, 2016 1:58 am    Post subject: Reply with quote
Well there's some clean up but a lot of what needs clean up will be a series of metal parts so will be crisp but yes acetone is the key to this one since its solid ABS I'll be machining the barrels out of ally and the grip frame out of ally and the butt and the shot gun portion above the main barrel I'll be casting out of pewter and getting all the writing engraved on the side to match the film , a snub version may come available just in the process of that version now
PostPosted: Sat Mar 12, 2016 8:34 am    Post subject: Reply with quote
Sounds good mate!
