Propmainiac Community Member
Posted: Fri Dec 09, 2016 6:07 pm Post subject: 3d printed Blade Runner Blaster |
Hello all
First time posting here. Incredible amount of info here. Ive been building a Blaster that a freind of mine printed and gave to me. Ive been facinated by this prop for some time and im nearing completion. Ive been working on fitting lights and making the clip removable. The lights are in but not happy with my wiring. May redo it.[/img] |
Replicant 13 Community Member
Posted: Sun Dec 11, 2016 4:39 pm Post subject: WELCOME! |
Welcome to The Summit, Maniac. Good luck with the outcome.
"(There's) no substitute for a good blaster at your side." - H. Ford from that OTHER franchise
- R13 _________________
Posted: Sun Dec 11, 2016 8:03 pm Post subject: 3d blaster |
Hi thanks!
Trying to wire the green leds. Scavenged two white wires to use. Hollowed out the sight rod and carved out a small hole for the white wires to run through. How do I post pics here
http://propsummit.com/upload/2801/image(1).jpeg |
Posted: Sun Dec 11, 2016 11:08 pm Post subject: POSTING PICS 101 |
Check your PM (upper-right button)- R13 _________________
Posted: Tue Mar 14, 2017 6:06 pm Post subject: |
http://propsummit.com/upload/2801/img_20170314_180141.jpg
Hi all here's my build so far. Lights are wired and working off one switch in the clip. The clip is removeable. The amber grips are from Richard Coyle and I have reworked the grip frame so they fit. Still need to repaint the grip frame and finish the buttplate. Adding real hardware as well. What do you think? |
Posted: Wed Mar 15, 2017 7:12 am Post subject: |
It's a great effort and the results look very good. Eager to see it all put together  |
Posted: Wed Mar 22, 2017 12:52 pm Post subject: |
| Ok no response? I thought this was the place? Oh well still working on it... Have to finish the buttplate yet. Weatherd it a little more and it looks great now! |
Posted: Wed Mar 22, 2017 4:20 pm Post subject: |
| Yep, looking good...what kind of paint are you using? |
Posted: Wed Mar 22, 2017 4:25 pm Post subject: |
| Just krylon satin black and on the receiver flat black with sliver dry rubbed into the paint. Silver model paint to simulate wear on the edges. |
rickhoward Community Guide
Posted: Wed Mar 22, 2017 9:14 pm Post subject: |
| Cool project. Good work! |
Posted: Wed Mar 22, 2017 9:42 pm Post subject: |
| Thank you so much! I'm finishing up the buttplate which is plastic like the rest of the gun. I'd love to find a real aluminum plate though. Ive been looking for a way to add weight to make it feel more real. |
Nexus7 Community Member
Posted: Thu Mar 23, 2017 10:01 am Post subject: |
| Looks pretty good. Is there any way to smooth, or fill in, those "ridges" that I see so much of in 3D printed stuff? |
Posted: Thu Mar 23, 2017 12:53 pm Post subject: |
| Thank you! Yes there is. Look on YouTube for acetone smoothing. The vapors from acetone will soften the lines. Also sanding. I did a combination of acetone, sanding and Bondo. The more the printer resolution the less lines. But they all have lines. |
