Drawing File for Steel Barrel
DaveG
PostPosted: Sun Dec 11, 2016 11:33 am    Post subject: Drawing File for Steel Barrel Reply with quote
These are the dimensions that I used for my run of barrels a couple years back. Anyone that got one of those barrels can tell you they fit perfectly. The tolerances of the various tapped holes and the relationship to the slot in the rear plug are critical so take care setting them up. Of note is that the slot in the rear plug is intentionally wider than the metal plate in the receiver around which it fits. This is to allow a little bit of rotational adjustment as the embedded plates are not always set squarely to the frame.
I am providing this file for free and clear use. Make one for yourself, make 1000 for sale. I don't care and I don't want anything for the use of the file. (Okay, if you make a thousand send me one!). I would request that you charge a fair price, both for the buyer and for yourself. I charged $50 each for my barrels, that was probably half what I should have charged. $100 a barrel would be a more than fair price considering the 24 odd machining steps these take to make.
Have a better one.
DaveG
Dave
rickhoward
PostPosted: Sun Dec 11, 2016 2:59 pm    Post subject: Reply with quote
Thank you, Dave.
Raygne
PostPosted: Mon Dec 12, 2016 12:42 am    Post subject: Reply with quote
Thanks Dave. Now to find a machinist to get one made.
First attempt at making something from scratch.
PostPosted: Mon Dec 12, 2016 2:30 am    Post subject: Reply with quote
Thanks Dave.
Dascoyne
PostPosted: Tue Dec 13, 2016 10:55 am    Post subject: Reply with quote
Thanks, Dave!
DaveG
PostPosted: Sat Dec 31, 2016 4:23 pm    Post subject: Reply with quote
I've received some inquires about using my drawing file to make a steel barrel for Off World and other blasters. These dimensions were based on the barrel from the Tomenosuke Blaster. I have no idea how well, if at all, it'll work with other makes of blasters.
Dave
