Where to get 12 volt Battery Holder
PostPosted: Wed Dec 19, 2007 3:02 am    Post subject: Where to get 12 volt Battery Holder Reply with quote
I am having no luck at Radio Shack, Frys, or online. ANyone know where to get a single 12v Battery holder either online or in the SoCal area?
Thanks
amish
PostPosted: Wed Dec 19, 2007 8:45 am    Post subject: Reply with quote
Is this what you are looking for? I am not electronically skilled, so I am unsure exactly what a single 12v Battery holder is to be honest.
http://www.cheaperthandirt.com/68051-51531-1231.html
Tom
www.propsummit.com
www.bladerunnerprops.com
Masao
PostPosted: Wed Dec 19, 2007 7:13 pm    Post subject: Reply with quote
The first question is: what kind of 12v battery??
If you can describe it, that wil help us help you.
PostPosted: Wed Dec 19, 2007 10:07 pm    Post subject: Reply with quote
Its a 23A looks like a small "N" type battery - not a watch battery.
Once-bitten
Banned!
PostPosted: Thu Dec 20, 2007 11:01 am    Post subject: Reply with quote
I can get you one if you would like and send it along with that other item we discussed...?
I got my 12V holder at a local Electronics shop.
Let me know!
MsGeek
PostPosted: Thu Dec 20, 2007 1:17 pm    Post subject: Reply with quote
For any kind of electronics you should check these guys first:
http://www.allelectronics.com/
They are local to me so I often find myself going in there just to check out what they've got. However, they are great to deal with online from what I understand from my costuming buddies, many of whom live far enough from Van Nuys, CA to where going there would be a major expedition.
Great prices on excellent stuff, both for working electronic parts and for greeblie/nurnie hunting.
Sushi, that's what she called me. Cold fish.
Gusmanb
PostPosted: Fri Dec 21, 2007 8:19 pm    Post subject: Reply with quote
BLW Did you know that An "N" Battery Holder will also work for the 23A's.
I Actually just recently was looking for them too and Some one at Radio Shack told me that An "N" holder will do the Job:
I needed them for my Snub Project: http://propsummit.com/viewtopic.php?t=625
PostPosted: Fri Dec 21, 2007 10:16 pm    Post subject: Reply with quote
I tried the 12v in the "N" holder and the LEDs worked but the battery got super hot. Did you find this as well in your buildup?
Thanks
Gusmanb
PostPosted: Fri Dec 21, 2007 11:59 pm    Post subject: Reply with quote
Thanks
You might have to get A higher ohm rated resistor.
Do not forget to hook up the resistor to the + wire on the Holster and than the LEDS after that.
May I ask what is your project?
is it A Blaster too?
This Website Might Help.
http://www.kpsec.freeuk.com/components/led.htm[url]
PostPosted: Thu Dec 27, 2007 11:52 am    Post subject: Reply with quote
Try a low voltage, I use a 3 volt battery on my models and hook the LEDs parallel.
