Yep, another Voight-Kampff project
Goto page Previous  1, 2
PostPosted: Thu Dec 07, 2017 7:45 am    Post subject: Reply with quote
Good research and mock-up Hellnback and thank you Colin for having re-posted Mark Stetson's pics (as you can see on the last one, the little fins are clearly visible at the bottom of the trench )
The bellows are actually resting on the side of the machine. The one piece vac-form housing is therefore higher than the sides...hence the difference in height that you saw on the blueprint.
Man, that prop is sooo difficult to do right Confused
Hellnbak
PostPosted: Thu Dec 07, 2017 1:09 pm    Post subject: Reply with quote
Colin,
All good points, but I have to disagree about the arm placement. To me it just doesn't work as showing the angle of the head resting in the trench, seems all wrong for that. And the lines projecting up and to the left would be unnecessary for that, to me they look like an indication of the arm in the raised position. But hey, you know what they say about opinions, and the point is moot anyhow Laughing
I've been messing with this thing, and here's how it's looking so far. Quite a mess, to be sure....
but somewhere in there some sort of Voight-Kampff is slowing emerging. I think.
Steve
Politicians are like diapers.....they both need to be changed often, and for the same reason
Hellnbak
PostPosted: Thu Dec 07, 2017 1:16 pm    Post subject: Reply with quote
Thanks, Joberg. Someday a video will emerge showing the actual building process of this beast, and all our questions will be answered. Right?
Yes, it's very difficult to build something right when nobody knows what right is for this thing Rolling Eyes
Hellnbak
PostPosted: Sat Dec 09, 2017 8:57 am    Post subject: Reply with quote
Had to take some time off from my project, furnace went out, and that's not a good thing to have happen when in Michigan. In December.
But I did make some progress on building some sort of model using the PropShop drawings. Not sure how useful it will be, none of the projected lines lined up, had to made a lot of semi-educated guesses. But this is what I ended up with....
And can someone tell me what this is in the indicated area?
PostPosted: Sat Dec 09, 2017 9:41 am    Post subject: Reply with quote
Looking good Hellnbak.
I think those lines are the projection of the six vertical fins. Just how far they stick out in plan view.
If that makes sense.
Colin
Ripley: What's it key on?
framed
PostPosted: Fri Dec 27, 2019 4:42 pm    Post subject: Reply with quote
Hi Hellnbak,
It's been 2 years now since your last post. I am quite interested how far you are now?
Regards,
Ray
always a pleasure
Hellnbak
PostPosted: Sun Jul 12, 2020 12:44 pm    Post subject: Reply with quote
framed wrote:
Hi Hellnbak,
Regards,
Ray
Ray,
Just came across my VK Model while browsing thru my folders. It's been a long time since I played with it, and it prompted me to visit the forum here to see what has been going on. A lot to catch up on, it will take some time.
Hope everyone is doing well and staying safe.
Steve
Hellnbak
PostPosted: Sun Jul 12, 2020 12:45 pm    Post subject: Reply with quote
framed wrote:
Hi Hellnbak,
Regards,
Ray
Ray,
Steve
Hellnbak
PostPosted: Sun Jul 12, 2020 12:46 pm    Post subject: Reply with quote
framed wrote:
Hi Hellnbak,
Regards,
Ray
Ray,
Steve
Hellnbak
PostPosted: Sun Jul 12, 2020 12:59 pm    Post subject: Reply with quote
framed wrote:
Hi Hellnbak,
Regards,
Ray
Ray,
Steve
Hellnbak
PostPosted: Sun Jul 12, 2020 1:12 pm    Post subject: Reply with quote
Ray,
Steve
Hellnbak
PostPosted: Sun Jul 12, 2020 1:16 pm    Post subject: Reply with quote
Sorry for the multiple posts. Each time I would attempt to post my reply it would give me an error message. So I kept trying. Had no idea that it was actually posting my reply even tho it was telling me that it couldn't because of an error.
PostPosted: Sun Jul 12, 2020 1:56 pm    Post subject: Reply with quote
That's right...despite the "error" msg, your first try in the good one Wink
Hellnbak
PostPosted: Sun Jul 12, 2020 1:59 pm    Post subject: Reply with quote
Embarrassing though Embarassed
Hellnbak
PostPosted: Sun Jul 12, 2020 2:00 pm    Post subject: Reply with quote
And I'm still getting the dang error message each time. Any ideas on that?
PostPosted: Sat Jul 18, 2020 10:08 am    Post subject: Reply with quote
Not embarrassing since it's not your fault Wink Andy will fix it
Hellnbak
PostPosted: Thu Jun 24, 2021 8:05 pm    Post subject: Reply with quote
Well, almost another year has passed. thought I would check in to see what's going on here in the forums. Thinking about continuing my VK project, but I have a lot going on right now so I'll have to do what I can when I can.
Hope everybody made it thru all the madness ok
Hellnbak
PostPosted: Thu Jun 24, 2021 8:15 pm    Post subject: Reply with quote
I see the error msg problem is still around. I got this msg when I attempted to post the above message, but when I checked I found that the message had actually posted ok, just like before.
Well, it's been so long I've forgotten how to post an image here. Here's what the error msg said --
General Error
Failed sending email ::PHP::
DEBUG MODE
Line : 234
File : emailer.php
Any idea what this means?[/img]
PostPosted: Fri Jun 25, 2021 9:16 am    Post subject: Reply with quote
Glad to know that the V.K. project is still in the works...despite real life making it difficult, sometime, to work on our favorite props/models.
As for that error msg...I'm afraid I cannot help you there. AFAIC, I can still upload pics without any problems. Wink
Page 2 of 2
