How is the Blaster ment to work theoretically? Am confused.
Goto page Previous  1, 2
PostPosted: Mon Jan 28, 2008 2:21 am    Post subject: Reply with quote
In the book it was Mars, there's a part where Pris is describing it as a place that feels really old.
ocd
PostPosted: Mon Dec 27, 2010 11:37 pm    Post subject: Reply with quote
Excerpt from 2019 edition - Owners manual OffWorld 2019C BRU.
The L.A.P.D. Model 2019C B.R.U. Blaster style firearm has a swing out type cylinder and clip type loading function.
Cylinder operation:
The swing out cylinder is located on the left side of the firearm and is a .38 or .44 caliber depending on firearm model. This is a chamber turning around a central axis which allows you to fire five consecutive shots before reloading the cylinder. When the cylinder is in the closed and locked position the firearm is ready for firing. The shots may be fired by pulling the rear trigger releasing the hammer on the cartridge causing it to fire. This is a double action only revolver. It cannot be “cocked” ready to fire. When the trigger is pulled it fires a cartridge, and advances the cylinder one cylinder, aligning the next cartridge in the cylinder with the firearm barrel to the ready to fire
position. Load the firearm by placing a cartridge in each cylinder. When all cylinders have a cartridge you are ready to fire. You are limited to how fast you can pull the trigger as to the speed of firing all five of the cartridges in the firearm. To re-load the firearm, open the cylinder and push the extractor rod until the spent casing fall out of the cylinders. You are now ready to re-load the firearm.
Clip type loading operation:
The sonic charge clip access port is located in the lower front of the firearm below the barrel. It is marked with 222Rem. text. To open the port, pull down on the rear portion of the port cover until it “pulls away” from the firearm. This aria loads a five round 10MM caseless
Sonic Shock cartridge clip. The clip MUST be placed with the cartridges in contact with the sonic charge energy converter leads to be activated. Once the clip is loaded, to activate the Sonic Shock cartridges, close the port by re-inserting the port cover and sliding the activator switch on the right side of the clip housing forward until the side and bottom red LED’s light up. If the LED’s DO NOT light, you need to change the Sonic Charge HI Energy Lithium Battery. The firearm is now ready to fire. To fire the sonic fire mode, pull the forward trigger. This is also a double action style trigger and cannot be “cocked” ready to fire. It is an “Auto Fire” trigger. When the trigger is pulled it fires a cartridge and will continue to fire until clip is empty or the trigger is released. To re-load the firearm, reverse the above procedure until the port is open, extract the spent sonic shock clip and replace it with a full clip.
NOTE
: DO NOT ATTEMPT TOTO FIRE BOTH TRIGGERS SIMULTANEOUSLY. THIS WILL RESULT IN A JAMMING SITUATION.
L.A.P.D. Model 2019C B.R.U. 10 MM CasEless - Operation
WARNING: Always handle live ammunition with care.
Sonic Shock cartrrtridges are extremely dangerous and should be handled accordingly.
http://propsummit.com/upload/949/ow_m2019c_lapd_bruinstg_page_01.jpg
http://propsummit.com/upload/949/ow_m2019c_lapd_bruinstg_page_02.jpg
http://propsummit.com/upload/949/ow_m2019c_lapd_bruinstg_page_03.jpg
http://propsummit.com/upload/949/ow_m2019c_lapd_bruinstg_page_04.jpg
http://propsummit.com/upload/949/ow_m2019c_lapd_bruinstg_page_05.jpg
http://propsummit.com/upload/949/ow_m2019c_lapd_bruinstg_page_06.jpg
http://propsummit.com/upload/949/ow_m2019c_lapd_bruinstg_page_07.jpg
http://propsummit.com/upload/949/ow_m2019c_lapd_bruinstg_page_08.jpg
http://propsummit.com/upload/949/ow_m2019c_lapd_bruinstg_page_09.jpg
http://propsummit.com/upload/949/ow_m2019c_lapd_bruinstg_page_10.jpg
http://propsummit.com/upload/949/ow_m2019c_lapd_bruinstg_page_11.jpg
http://propsummit.com/upload/949/ow_m2019c_lapd_bruinstg_page_12.jpg
Page 2 of 2
