Posted: Fri Jun 13, 2008 10:44 am Post subject: Side panel musings . . . |
SO, I was watching mythbusters and the cute red head (Kari Byron, not Adam Savage) sculpted a ring out of wax, and then had it cast in pewter.
Suddenly I wondered aloud . . .
Could this simple method be how the side panels were created for the blade runner blaster?
Because everything in my world some how relates back to this prop. I swear.
And what about the possibility of pewter as the material used on the side panels? Maybe even the buttplate?
Pewter doesn't rust, correct? _________________ I don't have enough blasters! |
darkknight0667 Community Guide
Joined: 11 Apr 2006 Posts: 799 Location: Land O Lakes, FL
Posted: Fri Jun 13, 2008 10:50 am Post subject: |
So, let me get this straight, Noeland . . . a snappy-looking lady like Kari is on your TV and you're thinking about the BR blaster? Dude, that's wrong.  _________________ Pete |
4yearlifespan Community Member
Posted: Fri Jun 13, 2008 11:05 am Post subject: |
LMAO |
Posted: Sun Jun 15, 2008 4:44 am Post subject: Re: Side panel musings . . . |
Noeland wrote: | SO, I was watching mythbusters and the cute red head (Kari Byron, not Adam Savage) sculpted a ring out of wax, and then had it cast in pewter.
Pewter doesn't rust, correct? |
I'm pretty sure you can find the correct wax at Blick art supplies. I've seen various chunks of modeling wax there. Some of it is quite expensive though, like $30-40 or so for a piece the size of a small bar of soap. I've never messed with it myself. My major only required basic sculpture, so I never took the classes up to wax sculpting and casting. _________________
SLK Community Member
Posted: Sun Jun 15, 2008 11:40 am Post subject: |
It's possible.
For some of the master patterns(guns, swords etc ) I make for work I need to sculpt wax. When a rubber mold is made the cast parts come out as well as if I used plastic on the master.
Pewter turns a darker grey as it's form of rust as I recall. |
SaberFreak Community Member
Joined: 24 Jun 2007 Posts: 111 Location: Somewhere in the outer-rim planets
Posted: Tue Jun 17, 2008 8:39 am Post subject: Re: Side panel musings . . . |
Ah, finally something I know a little bit about: Wax sculpting and pewter. No I don't do wax sculpture or pewter casting, but I've worked in one of the world's biggest pewter manufacturing company before and they sculpt most of the pieces in wax.
Noeland wrote: | Pewter doesn't rust, correct? |
There are many types of pewter. If its made from tin & lead alone, then it won't rust. It will tarnish (like silver) if the surface is not sealed.
Pewter for modern tableware is made up of tin, copper and antimony (copper & antimony for strength), so sometimes slight oxidation can occur if the copper is not mixed evenly. Lead is not used in this type of pewter due to it being toxic.
I was around warehouses full of pewter items for almost 2 years and I haven't seen a single piece of rusty pewter before.
The Loyalizer wrote: | Some of it is quite expensive though, like $30-40 or so for a piece the size of a small bar of soap. |
But you can use it almost indefinitely. Once the mold is made you can remove the wax sculpt and recycle it with hardly any lost in the wax content. Of course you also need to be mindful to collect the scraps while you're sculpting and not let them get blown all over the place. |
Posted: Tue Jun 17, 2008 11:15 am Post subject: |
Cool, thank you for sharing that SF. I'm just now (edit) getting into the world of metal casting and it's a subject I'm finding to be pretty interesting.
Posted: Thu Jun 19, 2008 4:39 am Post subject: Re: Side panel musings . . . |
SaberFreak wrote: |
I was under the impression that when the mold was heated, the wax melted out of it and was otherwise discarded, at least I think thats how its done for bronze casting with a plaster mold. I'm probably wrong tho.
The block I saw at the art store was way too small for the side cover with the steyr bolt lever, but you might have been able to work up the cylinder cover from it, but it looked like you wouldn't have much wax left over once you were done carving it. _________________
TridCloudwalker
Posted: Tue Jul 29, 2008 9:52 pm Post subject: |
If someone wants to sculpt a master out of two part epoxy putty (either the white plumbers stuff or the blue/green compound), and if there's an interest, I can cast pewter in my father's factory. We'd be looking at maybe $20 - $40 for a plate and butt set.
In my opinion though, the pieces were machined aluminum. With as many bumps and falls that gun took, there'd be dents and gashes galore in pewter pieces. |
