Force Badge resurrected
SynaMax
PostPosted: Tue Jun 04, 2013 12:52 pm    Post subject: Reply with quote
BeastMaster wrote:
Cheers guys Smile will hopefully have this printed on Wednesday so might have some images in the week. I'm also keen to do a full size police version. Does anyone know the dimensions of the original?
The circle in the center is 30mm, if I remember correctly. I'll also measure my eltree badge, just in case.
Also, the medallion in the center is a found part...it's from these belt buckles that you can put your picture or a coin in.
To be honest, I prefer a one-piece badge rather than having to disassemble the badge to install a new picture...less work, lol.
PostPosted: Tue Jun 04, 2013 3:04 pm    Post subject: Reply with quote
cheers, those measurements would help Smile I have a silver one of those buckle rings. will have to dig it out.
SynaMax
PostPosted: Thu Jun 06, 2013 3:25 pm    Post subject: Reply with quote
The dimensions for eltree's badge is 4 1/8" H x 3 1/8" W (at it highest and widest points).
tain669
PostPosted: Mon Jul 22, 2013 8:39 pm    Post subject: Reply with quote
Are you going to start making these?
PostPosted: Tue Jul 23, 2013 4:15 pm    Post subject: Reply with quote
hopefully in August I will get the final version 3d print done. I've got all the mold making kit etc. Though the metal casting will be the big hurdle in all this.
PostPosted: Thu Jul 25, 2013 5:13 pm    Post subject: Reply with quote
Eager to see the result for sure Beast
PostPosted: Fri Apr 18, 2014 4:23 am    Post subject: Reply with quote
I know this thread is alsmost 1 year old..... But did 3D printing ever happen?
PostPosted: Sun Apr 20, 2014 6:16 am    Post subject: Reply with quote
Wow! Time flys! Smile I'm going to try to print this out at work in the week. Then its the nightmare task of casting it in metal. I also wanted to cast a full size version as I have an original picture ring to fit on it.
PostPosted: Sun Apr 20, 2014 9:20 am    Post subject: Reply with quote
The best world would be to do it with the picture ring not on it so you could either buy the picture ring or cast it alone.
Then people could add their own pictures to it.
I might be interested in trying to cast it in pewter.
I think I would be best if I got a couple of plastic copies and then make either a hand poured molds OR have a spin cast mold made.
The spin cast mold might hold two to four units.
PostPosted: Sun Apr 20, 2014 2:44 pm    Post subject: Reply with quote
That sounds very cool... Hope to see some pics!
If you in any way could be interested in doing more than one, I would deffinetly be interested in bying one!
PostPosted: Thu Apr 24, 2014 2:39 am    Post subject: Reply with quote
The wallet size version would be the only version with the ring included. The printer at work is a bit rubbish so might have to go with shapeways.
Rich, sounds good to me, you're much better at metal casting than I am Wink I will see if I can get a copy sent to you.
eltee
PostPosted: Fri May 02, 2014 5:50 pm    Post subject: Uniform Badge Reply with quote
Rich "The best world would be to do it with the picture ring not on it so you could either buy the picture ring or cast it alone.
Rich"
I have my original molds, my original sculpts, etc. for the large badge. The badge and ring are separate and the "gorget" piece (says "POLICE 995") is a cast of its own. I went through two metalsmiths, both jewelers, for my large and wallet badges. If you are interested in casting, my sculpts and molds are in decent shape. The jeweler used a lost wax casting method so the molds are of a soft material.
PostPosted: Fri May 02, 2014 6:01 pm    Post subject: Re: Uniform Badge Reply with quote
Yes I would and thank you.
I have the other one and with a little work can set up to do them as well.
Rich"
PostPosted: Sat May 03, 2014 6:12 am    Post subject: Reply with quote
The picture rings can be bought fairly cheap without the belt buckle. The 38mm is the inside diameter....
http://www.eloxite.com/store/product.php?id_product=2548
PoD
PostPosted: Sat Sep 06, 2014 8:44 pm    Post subject: Reply with quote
Hows this build going? I am making the other wallet bits and am looking forward to getting a badge to go in there too Smile
PostPosted: Sun Sep 07, 2014 8:18 am    Post subject: Reply with quote
Welcome to Propsummit PoD...as you can see, it's a work in progress.
I'm sure the other members involved will chime in and give us some news on that WIP.
stonedog7563
PostPosted: Sun Sep 07, 2014 9:09 am    Post subject: Reply with quote
Would be interested also.
PostPosted: Mon Sep 08, 2014 5:51 pm    Post subject: Reply with quote
Hey folks, once I get the card project done and dusted I'll be back onto my other projects including this one. Got a 3d print done at work, though the printer is not too good so hopefully we'll be getting a better one in soon Wink
electronic_matt
PostPosted: Tue Sep 09, 2014 8:11 am    Post subject: Reply with quote
Beastmaster could you possibly send me the STL file? would like to have a go printing this
PostPosted: Mon Nov 10, 2014 7:54 pm    Post subject: Reply with quote
So getting this printed at work overnight on our new resin printer. Also we have acquired a laser cutting machine that cuts acrylic, so perfect for the picture window inserts. If I do a run of these I will include a picture of Deckard to go inside.
Page 2 of 5
