My Blade Runner (new guy)
Goto page Previous  1, 2
PostPosted: Sun Nov 30, 2008 1:47 am    Post subject: Reply with quote
Many thanks. Very Happy
superjedi
PostPosted: Sun Nov 30, 2008 10:00 am    Post subject: Reply with quote
Thanks for the tips on your process! It came out great.
repdetect
PostPosted: Sun Nov 30, 2008 4:41 pm    Post subject: Reply with quote
Thanks for the tip Han, i'll do that as soon as i get time !...Also i suppose you guys noticed that the 4 seams were too thin contrary to the screen used one...so i thought about having it done again by a dressmaker with some thicker thread...
chew
PostPosted: Mon Dec 01, 2008 1:53 pm    Post subject: your trench coat? Reply with quote
who made the coat? Is that the abbyshot version?
PostPosted: Tue Dec 02, 2008 1:35 am    Post subject: Re: your trench coat? Reply with quote
Certainly looks like it. The v.2 as the collar is bigger on that one. Its a good coat, just plan on getting wet if you use it as a rain coat.
Rachael
PostPosted: Wed Dec 03, 2008 5:03 am    Post subject: Reply with quote
If you do take the shirt to have the stitching beefed up, you might want to make sure that the tailor/dressmaker uses a stabilizer so the fabric doesn't buckle.
I found a backstitch or satin stitch allows you to use regular thread, which has a greater color variety. Often heavier thread has limited options since it is intended for construction intead of detailing and most home sewers just use all-purpose thread.
A backstitch means the needle goes over the same spot more than once, laying down a thicker line than just one pass does; a satin stitch is a very narrow zigzag that is close together, similar to a buttonhole on a shirt. I've used both and both are very effective in making a line of stitching pop.
Is this testing whether I'm a Replicant or a lesbian, Mr. Deckard?
repdetect
PostPosted: Wed Dec 03, 2008 5:31 am    Post subject: Reply with quote
Many thanks for the tip Rachael ...i will ask to the sewer if she can do that !...
repdetect
PostPosted: Thu Dec 18, 2008 1:55 pm    Post subject: Reply with quote
I wasn't totally satisfied with my Deck's shirt...let me explain the fabric is good imo but the overall look is off. I wanted first to use black dye like Han Jones did with his shirt but, even if it was a good alternate answer, faded the nice blue and pink colors...The less i could say is that i didn't choose the easy way out but finally i think the result was worth the time i spend on it...So here it is :
Yep ! i finally bought a few grey color specific marker to do the job, this last one consisting in coloring the white crossed lines in grey !
At the very end i used no less than 12 of these markers, of course it was a work of patience and as my grandpa always said, all good things take their time !!
Of course, to finalise the work, i had to iron the shirt to fix the grey color particularly if i want to wash my shirt...
PostPosted: Thu Dec 18, 2008 11:09 pm    Post subject: Reply with quote
That is exactly what I was thinking about doing if I got the shirt. I want to know more about these markers. My other idea was to do a Batik technique putting wax in the colored areas and dying the rest of the shirt darker.
photek
PostPosted: Fri Dec 19, 2008 1:09 am    Post subject: Reply with quote
Beautiful work Phil!
now that is the true definition of a labor of love.
well done my friend!
two legs bad, four legs good.
PostPosted: Fri Dec 19, 2008 8:27 am    Post subject: Reply with quote
Excellent work. Bravo! It looks used.
superjedi
PostPosted: Sat Dec 20, 2008 9:33 am    Post subject: Reply with quote
Wow! Amazing results. Your shirt looks terrific.
repdetect
PostPosted: Sat Dec 20, 2008 4:44 pm    Post subject: Reply with quote
Well, i don't know much about Batik, the marker is quite a common one, mine is from Pebeo brand...I think you can find that kind of pen almost everywhere !
repdetect
PostPosted: Sat Dec 20, 2008 4:53 pm    Post subject: Reply with quote
Photek, Joberg & Superjedi :
Thanks guys, with the hours i spent on it i would have been disapointed if the stuff turned out bad !! Very Happy
chew
PostPosted: Mon Jan 12, 2009 7:57 pm    Post subject: Reply with quote
Boy, filling this shirt in with the fabric pen takes time... How long did it take you? I dyed mine first to look like Han's but it still didn't read black enough, so I am adding the repdetect look. Its looking great will post pics when done...
I just do eyes.
Page 2 of 2
