The Tomenosuke Blaster Kit: A Closer Look
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9, 10  Next
PostPosted: Mon Dec 22, 2008 11:54 am    Post subject: Reply with quote
I think it may be time to open up the review section and put this stuff in there.
Finbladerunner
PostPosted: Mon Dec 22, 2008 1:21 pm    Post subject: Reply with quote
I love the word "BLÄSTER" they use! Sounds very finnish pronounced word.
PostPosted: Mon Dec 22, 2008 5:55 pm    Post subject: Reply with quote
Or German can also put the umlaut on the vowel A; maybe to respect the ''made in Austria'' text on the gun.
temponaut
PostPosted: Mon Dec 22, 2008 10:05 pm    Post subject: Reply with quote
phase pistol wrote:
Great pics, Temponaut!
Thank you, phase pistol! Very Happy
temponaut
PostPosted: Mon Dec 22, 2008 10:06 pm    Post subject: Reply with quote
I hadn't realized there was a review section. Or do you mean we should create a dedicated forum on the board for reviews?
Either way, I have no objection to the thread being moved wherever you see fit.
temponaut
PostPosted: Mon Dec 22, 2008 10:20 pm    Post subject: Reply with quote
I thought it might have been a visual gesture toward the weird amalgam of languages represented by Cityspeak, analogous to the macron over the O in "Vid-Phon," although less logical. (The macron over the O would result in "Vid-Phon" being pronounced "Vid-Phone," but the umlaut over the A in "blaster" would result in a pronunciation similar to "blester.")
Thanks, Pilot!
PostPosted: Mon Dec 22, 2008 10:56 pm    Post subject: Reply with quote
I had started a review section, but it isn't public yet. I was getting so many questions on what Blaster was best,I figured it would be helpful to have a place to point people to so they could decide on their own. I only did one review of the offworld a long while ago. Maybe we could allow reviews from everybody instead.
temponaut
PostPosted: Tue Dec 23, 2008 12:45 am    Post subject: Reply with quote
That's a great idea.
Maybe you could put a stickie at the top including your history of the BR Blaster and replicas, and members could then post their personal evaluations and photos of various models. It would make an excellent resource.
PostPosted: Tue Dec 23, 2008 1:07 am    Post subject: Reply with quote
Exactly! It would also have a poll that could help rate each blaster variation on each of the main attributes. It would also act as a identification guide.
I was thinking along the lines of something that someone new to the hobby could use to find what they are looking for or at least help refine their searches. The seasoned collectors could also use it as a show off thread.
Hasenbrau
PostPosted: Tue Dec 23, 2008 2:13 am    Post subject: Reply with quote
That certainly sounds like something that could help us new guys out. Very Happy
temponaut
PostPosted: Tue Dec 23, 2008 2:15 am    Post subject: Reply with quote
Yes, definitely sounds like something good for both new guys and old hands. There are already several reviews on the board that could go into the new forum. Very Happy
PostPosted: Tue Dec 23, 2008 2:18 am    Post subject: Reply with quote
Great pics man! really gives a good idea of the quality of the parts. Question about the plastic parts:
Are they made from ABS plastics like on a high end airsoft, or is it some other type of plastic?
On the finished kit, has the receiver been painted or blued?
temponaut
PostPosted: Tue Dec 23, 2008 2:27 am    Post subject: Reply with quote
Thanks! I hope members will find the pics helpful.
Question about the plastic parts: Are they made from ABS plastics like on a high end airsoft, or is it some other type of plastic?
Good question. I'm not sure of the answer. The cylinder is made of a different type of plastic than the other parts. I'll send an inquiry to Tomenosuke Shoten about the type of plastics used. It will also be an opportunity to ask about the decision to make the cylinder covers and hammer in plastic instead of metal.
I'll report back when I have an answer.
The receiver and barrel jacket have both been blued, not painted.
temponaut
PostPosted: Tue Dec 23, 2008 2:30 am    Post subject: Reply with quote
Here's the third installment of photos: the metal parts.
These are the machined parts: Barrel jacket, laser sight, and assorted rods and pins.
The jeweler's screwdriver is open from one end to the other (top photo) and there is an access hole forward of the two smaller, threaded holes through which the sight is secured to the left cover (bottom photo), so that the LEDs at either end of the sight could be wired for illumination if so desired. The finished Blaster as sold by Tomenosuke Shoten, however, has no wiring to the sight; the five LEDs in the magazine and housing are the only ones that light up -- suggesting perhaps that, like some members here, the folks at Tomenosuke believe the sight wasn't illuminated in the film.
In addition to the standard barrel jacket, Tomenosuke Shoten also machined a limited number with a higher caliber bore. In the first photo below, the standard barrel included with the kit is shown on the left and the large bore barrel is on the right; in the second photo, the standard barrel is on the bottom and the larger bore is on the top. I believe that these larger caliber barrels may actually have been made by mistake. In any case, Tomenosuke Shoten has made them available as an option for purchase on the kit's ordering page; if you buy one, you'll receive it in addition to (not instead of) the standard barrel. For those of you looking to upgrade a Hartford or other plastic Blaster with metal parts, this might be an interesting option, although I have no idea how easy a fit the piece would be.
The cast white metal receiver and bolt assembly.
Another angle of the raw receiver. As on the actual WorldCon Blaster, the pointed tip of the bolt retracts into the front cap when the bolt is drawn back.
The parts that make up the receiver and bolt assembly. There is one more part -- the front cap -- which in this picture is still in its place at the front of the receiver.
Lettering on the receiver is crisp. In the background you can see the side of the kit box with the Kanji character toku (for "Toku Nobutaka," who created the prototype for the kit) in foil.
Parts of the grip frame assembly. The second shot shows how precisely the parts fit together.
Detail shot of a threaded hole that has been pre-tapped into the grip frame.
Ejector, right cover knob, Weaver knob and "minus" screw head, safety switch, and cylinder latch. The two L-shaped pieces at the lower left are the mounting arms for the interchangeable Weaver knob and screw head.
A closer look at the ejector. The part measures 16mm at its broadest point. The details are beautifully cast. Note, though, that on the finished model the cylinder does not spin with trigger pulls and the ejector does not actually eject the shells. (The shells can easily be removed with the help of gravity.)
A better look at your choice of knobs. Sorry about the blurriness! Embarassed
Parts to make five shells are included. Each cartridge consists of two pieces.
The bottom of a cartridge rim. At first I thought that the text looked a little shallow, but after polishing and finishing the pieces look great. The second picture shows three finished shells.
Still more to come!
Thank you, Pilot!
jfuste
PostPosted: Tue Dec 23, 2008 3:49 am    Post subject: Reply with quote
mmmm sounds very interesting. It could be like a ID Guide for blasters.... I think many many time about this prop and how to deal with it in the book... So many variations and little differences netween, IMHO. So, a guide like this, with some clear identification points, could be very useful for insane collectors as me.... Razz
And... honestly, I think you are one of the best to achieve this guide... Don't you think? Smile
temponaut
PostPosted: Tue Dec 23, 2008 8:44 am    Post subject: Reply with quote
According to the Hollywood Collector's Gallery website, the second round of sales for finished Tomenosuke Blasters will begin at 13:00 on Wednesday, December 24 (Japan time), and delivery of the Blasters will take place at the end of February 2009.
Just in case anyone is interested. Wink
jfuste
PostPosted: Tue Dec 23, 2008 9:44 am    Post subject: Reply with quote
"And.... where..... " ejem! Will be this available thru online sales???
PostPosted: Tue Dec 23, 2008 12:05 pm    Post subject: Reply with quote
try here
PostPosted: Tue Dec 23, 2008 12:27 pm    Post subject: Reply with quote
Sharp looking parts, and great photos.
jfuste
try here
Thanks Andy! Wow.... Circa 480€.... Razz
Or $679,00....
Some pricey... for a unassembled kit, I guess. Well, will write a letter to something special these days... hohohoho!!!!
Page 2 of 10
