kurtyboy Community Member
Posted: Mon Apr 06, 2009 11:06 am Post subject: Blaster parts I'm still looking for. Please help :) |
I'm still looking for the following parts for my Sidkit WC style:
Metal cylindrical support that sits between the ammo box and the barrel at the front of the blaster.
The bolt that attaches the above parts.
The correct style switch.
Hollow metal laser sight/jewler's screwdriver. |
DeckB26354 Community Member
Posted: Mon Apr 06, 2009 2:17 pm Post subject: |
HI
I don't know if this helps but there are quite a few parts selling on eBay at the moment. Do a search for BLADE RUNNER PARTS.
Have a good one.  |
Posted: Mon Apr 06, 2009 9:29 pm Post subject: |
It looks like someone is selling a SidKit piece by piece in the UK to get around the gun replica ban, same with pieces of a Coyle too.
I will look to see what parts I have extra. I didn't pick up too much at the last gun show unfortunately.
BeastMaster Community Member
Posted: Tue Apr 07, 2009 7:37 am Post subject: |
the coyle receiver set looks like a good buy if you want a more accurate barrel. just a shame the receiver cover looks like it was hit by a meteor shower!
anyone know if the coyle and sidkit parts are compatable with each other? _________________ "F*ck it, it's just a movie. Let him worry about it" Harrison Ford |
Posted: Tue Apr 07, 2009 12:08 pm Post subject: |
The metal parts are not compatible and are slightly different Sizes. The parts will fit to some degree and the older Sid and Coyle's match pretty much perfectly. (I can hear Rich saying "Ah Ha" right now )
Sid's metal parts are slightly larger and he simplified the casts to make them easier to pull and finish (took off some of the detail and material). It also allowed him to use less metal in the casting. He also redesigned the pieces to make them easier to assemble, and not be confused for real gun pieces in case the cops came calling after him. The ATF is probably got Rich's house bugged at this point.
The grips should be interchangeable though, but new screw holes might need to be made. The receiver might also be retro fit.
