ALIEN RESSURECTION (The Betty)
IEDBOUNTYHUNTER
PostPosted: Sun Nov 29, 2009 1:23 pm    Post subject: Reply with quote
The overall shape looks spot-on Al...very good job so far.
Question: I would like to try using urethane foam as a buck for vacu-forming...any tip you could give me would be helpfull (any releasing agent I have to use on the foam, or do I have to use bondo to make the buck stronger)? Any help would be appreciated.
Thanks.
Thanks.
to use the foam for a buck for forming, first make sure your foam is at least 5 lb density. as for a release., make sure you get the foam as close to the shape you want, i would suggest if its spot on just primer it and sand smooth with 400 or finer, then you can dust it with baby powder or a thin coat of vaseline for a release.
i try not to add to much bondo if i dont have to. also it depends on how many pulls you are going to have to make. if you have any other question feel free to PM me.
Thanks Al
PostPosted: Mon Nov 30, 2009 4:17 am    Post subject: Reply with quote
Same here, impressed once more by your modeling skills and knowledge !!!
PostPosted: Mon Nov 30, 2009 7:28 am    Post subject: Reply with quote
Thanks for the tips Al, it's very helpfull.
IEDBOUNTYHUNTER
PostPosted: Sun Dec 06, 2009 5:48 pm    Post subject: Reply with quote
Thanks guys for checking this thing out.
I got a little more done on the flight deck. still a WIP, but its getting there. to cold to primer today, but ill get there soon. still need to add the details and shape the bottom. heres a few pics.
Thanks Al
PostPosted: Mon Dec 07, 2009 7:43 am    Post subject: Reply with quote
Lookin' good Al! Keep up the good work!
PostPosted: Thu Dec 10, 2009 1:17 am    Post subject: Reply with quote
Al,
Nice work as always. How far are you intending to go with any lighting and interior cockpit detail just out of interest?
IEDBOUNTYHUNTER
PostPosted: Thu Dec 10, 2009 5:37 pm    Post subject: Reply with quote
Thanks.
Im going to light the whole ship and do the cockpit with seats and minor detailing, with some lights. not really decided how far i want to go with it.
Al
IEDBOUNTYHUNTER
PostPosted: Sun Dec 13, 2009 6:25 pm    Post subject: Reply with quote
Back again, a little more done on this, still need to finish the underside, and sand and re prime, then ill add the window moldings and detail parts. but its getting there.
Thanks for looking.
Al
PostPosted: Mon Dec 14, 2009 7:26 am    Post subject: Reply with quote
Looking good Al...are you going to vacu-form the cockpit, or clad it with plasti-card or something else altogether?
IEDBOUNTYHUNTER
PostPosted: Mon Dec 14, 2009 5:42 pm    Post subject: Reply with quote
Im going to finish it completely and then mold it in silicone, and make a hollow copy out of Epoxy fiberglass. then im moving onto the tail.
Thanks Al
IEDBOUNTYHUNTER
PostPosted: Wed Dec 23, 2009 2:51 pm    Post subject: Reply with quote
Started hogging out the foam to fit the cockpit under the cone. still needs a little sanding but its getting there. also finish the underside details and add the plate and panel lines,and window moldings. but its getting there.
Thanks for looking.
Al
PostPosted: Sun Dec 27, 2009 3:34 pm    Post subject: Reply with quote
Looking very good Al! I'm eager to see that cockpit detailed
IEDBOUNTYHUNTER
PostPosted: Wed Jan 27, 2010 5:39 pm    Post subject: Reply with quote
Been awhile. but heres what i have so far. added the window moldings, which was a big pain in the butt. next i will add the plating and panel lines. then i will move onto the scorpion tail. after that should be all down hill.
thanks for looking.
Al
PostPosted: Thu Jan 28, 2010 7:37 am    Post subject: Reply with quote
Yep, all those joints must have been a royal pain (I feel for you Al) nevertheless, it's looking mighty good!!
PostPosted: Thu Jan 28, 2010 5:51 pm    Post subject: Reply with quote
Hey, it's great to have some news from this project, Al !
The photos are very impressive, as always... LOVE your very accurate work !
IEDBOUNTYHUNTER
PostPosted: Sun Feb 07, 2010 1:30 pm    Post subject: Reply with quote
Started molding a few parts, first up the small part behind the engine support.
Thanks for looking.
Al
Leveling the mold box.
pattern in the mold box.
Mold and casted parts and pattern.
PostPosted: Mon Feb 08, 2010 7:33 am    Post subject: Reply with quote
Looking good Al...are you using resin for your pieces?
IEDBOUNTYHUNTER
PostPosted: Mon Feb 08, 2010 8:03 pm    Post subject: Reply with quote
Yes, the smaller parts will be resin. the larger parts like the engines and the cockpit will be made out of epoxy fiberglass.
www.bootcampaign.com
Support the Troops.
PostPosted: Tue Feb 09, 2010 11:05 am    Post subject: Reply with quote
Fantastic work Al, this is looking great. You must be pleased with how it's going.
Mark Sheppard
PostPosted: Fri Feb 12, 2010 8:38 pm    Post subject: Reply with quote
Sign me up for the first one!
Page 4 of 6
