DonParker Community Member
Posted: Tue Dec 22, 2009 6:30 pm Post subject: Offworld and other machined gun parts. |
This is just a take off of my other thread.
I wouldnt mind hearing some ideas of what
some of you might want machined for the
offworld and other prop guns.
Don |
seesinsilhouette Community Member
Posted: Tue Dec 22, 2009 6:43 pm Post subject: mAchined offworld parts |
Hey. Aside from the bolt i'll kick this off by suggesting the rear section of the upper receiver.
Posted: Tue Dec 22, 2009 8:34 pm Post subject: |
Im workin on it. . |
Photech Community Member
Posted: Tue Dec 22, 2009 8:48 pm Post subject: |
those two parts would be the business _________________ No! 4, 2 - 2, 4. |
Posted: Wed Dec 23, 2009 3:18 am Post subject: Plus!! |
Ooh I forgot to also say bolt arm!!  |
Posted: Wed Dec 23, 2009 4:10 am Post subject: |
Wish I had a small cnc it would make doing these
parts alot easier. Of course if I had both a cnc lathe
and mill Id be machining a whole new gun from
aluminum solid.It would also be based of a .44
special. |
Posted: Wed Dec 23, 2009 4:30 am Post subject: |
Just a thought of what I wouldnt mind doing.
1. Butt plates: which Im doing at the moment
2. Bolt: when I made mine I did it in 2 pieces
because theres an undercut that the
bolt arm slides into.
3.Cylinder: adds some weight.
A few would like the barrel which may be an option
but heres the thing,when I put the steel barrel
on mine I had to cut the existing barrel off and
drill a hole in the frame for the new one.It may not
be the best way for some to go.If the frame gets
screwed up you may as well toss the gun. As the first 3 options
stand they are replacement parts that can be put
back to origional if need be. |
Posted: Wed Dec 23, 2009 4:40 am Post subject: |
Trigger Guard and outer grip frame.
andy |
Posted: Wed Dec 23, 2009 6:49 am Post subject: |
andy wrote: | Trigger Guard and outer grip frame.
andy |
I'm with Andy on this one.
If one where to send you a part could you machine it?
Thanks |
punctated Community Member
Posted: Wed Dec 23, 2009 7:00 am Post subject: |
I thought about the cylinder but does this add too much weight to an area that is already weak. At least on my OffWorld the swing out cylinder and cover seems to be the only piece where I have any movement.
I agree with DonParker regarding a steel barrel but what if the barrel was made from aluminum with a little tab that could be inserted into the hole where the barrel meets the cylinder chamber? Aluminum is obviously lighter than steel and I think could be secured with the existing screw attachments and some epoxy. However, with that said the barrel is the last replacement part on my list. The whole bolt and rear section as well as the trigger guard and outer grip frame are my first choices.
DonParker you make any replacement pieces for the OffWorld and I will buy them  |
Posted: Wed Dec 23, 2009 11:33 am Post subject: |
Well guys Ive made 2 grip frames but they take time.
so Ive been looking at the thread for the tomenosuke
blaster and how he machined that.That machine is
simular to the machines that I have and he uses a
rotary table with jigs for the radiuses. So I think that if
I get all the radiuses set on a jig just like that, the
outer grip frame is very doable.As a matter a fact I'm
making a jig right now for the butt plates.Obviously
machining just 1 doesnt require a jig but being
from a production environment I know jigs are
the way to go. |
Posted: Wed Dec 23, 2009 2:09 pm Post subject: |
I really like that bolt!! |
Posted: Thu Dec 24, 2009 10:03 am Post subject: |
Guys Im working on the butt plates however
its going a little slow.As im typing this the
temp outside is 5 degrees...global warming my a_ s.
Anyway Im also working on a master pattern
for the outer grip frame.Most of the money from
the butt plates will be going for tooling and aluminum
for making these.Anyways thanks again guys.
Don |
Posted: Fri Dec 25, 2009 8:00 pm Post subject: |
I was checking steyrarms.com tonight and they have ammo
magazines for the .222 rem. at $42.00.I may have to get one
for the pistol I'm making. |
Posted: Sat Dec 26, 2009 5:53 am Post subject: |
Those are the new style mags and are not correct for the BR blaster. |
Posted: Mon Dec 28, 2009 11:44 pm Post subject: |
Oh man that looks awesome. I really do need to get one of those now.
Posted: Tue Dec 29, 2009 1:50 am Post subject: |
PM sent regarding an order.
Great work! |
Posted: Tue Dec 29, 2009 7:28 am Post subject: |
Just received my butt plate and it is awesome. Very well done and the fit was perfect. I can not wait to see more.
Thanks Don |
