jameth Community Member
Posted: Mon Jul 12, 2010 4:33 am Post subject: |
Nice idea ,
I 'll see if I can source some thin steel strip and try to create some springs, as you've probably found the rear trigger spring isn't so hot either, as sometimes it sticks and the trigger doesn't return as it should . So I would strongly suggest changing the rear one as well. |
Posted: Mon Jul 12, 2010 6:21 am Post subject: |
Good stuff Jameth! Eager to see that new Coyle coming to life! |
Posted: Mon Jul 12, 2010 12:07 pm Post subject: |
propsjonnyb wrote: | Nice idea ,
Great idea. I would not mind if the swiss spring was just a tad stronger. It's works great but is a little light. A slightly stronger steel would feel real good. |
Posted: Tue Jul 13, 2010 5:02 am Post subject: |
Having watched the video, I would concur that bending the spring up at one end and drilling a small hole would be a good idea , a spot of superglue in the hole will fix the spring in place. The rear trigger already has a hole drilled in the trigger and a matching one in the gun frame , so bending both ends and fixing one end in the trigger ( superglue) and leaving the one in the frame un-glued should give fully working front and rear triggers, that will not stick and will always return . |
