megagreg Community Member
Posted: Wed Jul 07, 2010 1:54 am Post subject: Pewter Repair |
Hi all,
So I'm in the middle of my first SidKit build, and I've ran into a snag. Seems that the pewter was very thin near the back wall of the bulldog frame (where the cylinder would pop out). And while polishing this piece, I polished right through metal leaving a hole (see image).
To compound things, the spring loaded ejector pin/pivot (see image) now gets stuck in that hole every time I eject the cylinder. So I can't completely eject the cylinder without a lot a wiggling and wrestling the blaster.
Anybody have a repair technique for filling that hole?
Thanks much! |
REdYOdA Community Member
Joined: 27 May 2010 Posts: 41 Location: San Francisco
Posted: Wed Jul 07, 2010 3:38 am Post subject: |
I would recommend filling the damage with http://jbweld.net/products/jbweld.php
JB-weld is safe for use and bonds to softer metals. It's pretty easy to sand/paint after curing.
Your finish is looking great btw...hope to see some finished pics! |
Posted: Wed Jul 07, 2010 4:43 am Post subject: |
| You could repair the hole with a good lead free solder , simply 'blob' solder quickly into and around the hole , don't leave the soldering iron tip against the surface of the pewter gun for too long or you'll cause more damage than trying to fix the repair , you should end up with a raised 'pimple' of solder on the surface , file or grind it down with a dremmel again not too much grinding - finish with filing and sanding it smooth . |
Posted: Wed Jul 07, 2010 11:12 am Post subject: |
Thanks guys!
Some JBWeld is sitting right in front of me as I type this—so I'll probably try that method first. And I'll post some photos when the build is done.
All the best |
Posted: Sat Jul 10, 2010 11:40 pm Post subject: |
JB Weld worked great - thanks again! (solder might have been even nicer (a actual metal finish) but I was too chicken to try that method).
Posted: Sun Jul 11, 2010 12:49 am Post subject: |
Great repair job there mate…!!
Looking forward to seeing the rest of the build completed.
Regards
MARK _________________
Posted: Sun Jul 11, 2010 6:41 am Post subject: |
| I agree looking good, whatever works best - since I'm electroplating mine , I'd have used solder rather than epoxy , since , I need a material that's conductive - looking forward to seeing teh finished article |
Posted: Sun Jul 11, 2010 6:43 am Post subject: |
| Very good repair MegaGreg! Looking forward to more pics of your build. |
Posted: Sun Jul 11, 2010 7:51 pm Post subject: |
Thanks all !
Still working on it, but here's a sneak peak.
Still to do:
- electronics
- weathering & detail
- fix upper receiver and barrel alignment
Need More Help: What kind of battery is used in the SidKit? Mine came "batteries not included"
See here:
http://www.heycomputer.com/instruction/blaster9.htm
Thanks again ! |
Posted: Mon Jul 12, 2010 4:40 am Post subject: |
| You can use a 9v flat battery, which I am told Sidero always used, my Sidkit has a 9V inside, or as Rich does a 3v camera one ,the only thing to make sure about is the wiring for the LED's and the switch , and protect the circuit with a small resistor , if you don't know the specs on the LED's as an unprotected circuit and unknown LED's could cause them to overheat and burnout. |
Posted: Mon Jul 12, 2010 6:35 am Post subject: |
Lookin' good...keep up the good work  |
Posted: Mon Jul 12, 2010 1:09 pm Post subject: |
Thanks propsjonnyb
From the online instructions: ( http://www.heycomputer.com/instruction/blaster9.htm ) it looks like a 3v camera battery is being used. There was no resistor in the bag of electronics that came with the kit, so I'm thinking I don't need one for a 3v configuration (as opposed to 9v)? ? |
Posted: Tue Jul 13, 2010 4:21 am Post subject: |
| It depends on the specs of the LED's , if you don't know them assume 300 ma and add a small resistor, just to protect them from burnout , if you wire up the LED's incorrectly the circuit could get pretty warm and blow an LED damm shame if you've fixed it in place , most LED's will happilly work forever on 1.5v so try to keep it around that limit, the photos show them linked in series , I'd add a 10ohm or12 ohm resistor just to be on the safe side. |
Posted: Tue Jul 13, 2010 11:51 am Post subject: |
Great advice! Thanks much propsjonnyb. Off to the electronic store…
MG |
