Helder22 Community Member
Posted: Fri Sep 17, 2010 11:43 pm Post subject: The other trigger |
So what gun does the front trigger come from? A 40's S&W 38 revolver according to Rich's website. Whats the model? anyone know? Rich?
Helder |
Posted: Sat Sep 18, 2010 1:10 am Post subject: |
I just know that it is a K frame. Ridged of course. I used to think it was a combat trigger, but I was recently corrected that the combat version does not have the ridges.
Posted: Sat Sep 18, 2010 4:00 pm Post subject: |
Thanks for the info Andy, Ill start looking around. |
Posted: Sat Sep 18, 2010 4:44 pm Post subject: |
I can send you a casting that fits,
The real trigger takes a lot of grinding to cut it down to fit.
Are you doing one with a real Bulldog as I had to make some changes to fit the real pistol.
So there are two models prop adn real gun.
Posted: Sat Sep 18, 2010 6:50 pm Post subject: |
Thanks for the offer Rich. I'm using a real bulldog for this build. I was hoping to use all the found parts I could on this blaster, even if that did mean a little ( or a lot) more work. I will need a lot of parts from you though, like grips and other sculpted bits. If I can't find the right trigger then I'll take you upon the offer and get it along with the rest of the things I'll need. |
