Bassnoir Community Member
Posted: Sat Nov 06, 2010 3:29 pm Post subject: Offworld Upper Receiver Swap Instructions |
...could someone please post the instructions for removing the Old and replacing the New Offworld blaster Upper Receiver...I believe written with pictured instructions were sent out with the purchase of the New Upper Receiver...many thanks... _________________ ...the future is not all it's cracked up to be... |
steevy Community Member
Posted: Sat Nov 06, 2010 7:11 pm Post subject: |
| Its pretty easy bass.Just requires removing 4 or 5 screws.The only thing to be careful of is when putting them back.Since they are screwing into plastic they can strip easily. |
Posted: Sat Nov 06, 2010 9:42 pm Post subject: |
...thanks...the Offworld bolt is going to be replaced by one of Don Parkers...anything to be aware of with that swap?..... _________________ ...the future is not all it's cracked up to be... |
Posted: Sun Nov 07, 2010 7:33 am Post subject: |
| Yes the clearance for the bolt shaft, Don's bolt was sized for the Sidkit and can fit the Coyle with a bit of work , it's the thickness of the bolt that's the issue , the Coyle bolt itself , is appx half the thickness - so you have to grind or file the bolt to fit the grove on the gun frame , with the Offworld it would be advisable to do the inner receiver channel , the bolt itself and the top of the gun frame to ensure a good fit and a smooth action once you fit the parts back together again |
Posted: Mon Nov 08, 2010 2:02 pm Post subject: |
..many thanks.... _________________ ...the future is not all it's cracked up to be... |
