parkimete
bagnols
PostPosted: Thu Oct 20, 2011 7:16 am    Post subject: parkimete Reply with quote
I'm looking for all possible information about the parkimeter to build a 1:1 scale replica.
Searching in the net I found very few information.
Looking for all available angles pictures, measures and so on. A blueprint will be a great aid!
PostPosted: Thu Oct 20, 2011 7:30 am    Post subject: Reply with quote
There's a few good pics around the net (mainly from the movie and behind the scene stuff as well as a 3D CG rendering also).
As for blueprints...never saw those before. It seems that the overall ball-park dimensions are as follow: 4 1/2 tall, black base could be 12" wide and 24" tall, for the rest you'll have to wing it.
I know that OffWorld66 has a good sticker for the back (warning of electric shock and fees to be paid).
Good luck with the build
jfuste
PostPosted: Fri Oct 21, 2011 1:54 am    Post subject: Reply with quote
Thanks for the info joberg! In fact I'm with bagnols together in this project. Perhaps will be possible, who knows.... Very Happy
I didn't remember offworld66 has this sticker! Yeap. Will check it!!!
Thank you again!
PostPosted: Fri Oct 21, 2011 7:11 am    Post subject: Reply with quote
You're welcome...I thought long and hard about a similar project...no time to do it right now Crying or Very sad But, yeah, batteries for the lights can be easely stored in the base of the meter (you'll need 2 lights only, and one is a small neon tube for the lower one). Either plastic tubing and or cardboard can be used (I would go plastic Wink )...
Eager to see your results.
Bendzhamin1967
PostPosted: Fri Oct 21, 2011 1:11 pm    Post subject: Reply with quote
PM sent...
