The pointed tip above the barrel
kurtyboy
PostPosted: Mon Jan 16, 2012 6:20 pm    Post subject: The pointed tip above the barrel Reply with quote
I just realized what the funky looking pointed tip sticking out just above the barrel is on Deckard's gun.
See, what happend was that I had the part from my Sidkit lying in one of my spare parts boxes. Then recently while doing a clean out to sell some old stuff I no longer needed, I found it... then I found another... and another.... wait a minute! I only ever had ONE Sidkit.
Then I realized that lots of these little things had spilled into several of my spare parts boxes and it dawned on me what they were.
Vintage lead airgun pellets. I have a bag of them but can't remember where I got them...
Mine aren't quite as pointed as the one on the blaster but that's definitely what it is, no doubt about it.
PostPosted: Mon Jan 16, 2012 6:26 pm    Post subject: Reply with quote
Pics please? I know we had all thought they were a firing pin before this. Very Intriguing.
kurtyboy
PostPosted: Mon Jan 16, 2012 6:55 pm    Post subject: Reply with quote
Well I'm no firearms expert so I'm probably completely wrong!
But look at the resemblance:
Robotprops
PostPosted: Mon Jan 16, 2012 10:42 pm    Post subject: Reply with quote
It could be a tip from a spray gun. I've dissected a few to sub in for the pin...
PostPosted: Tue Jan 17, 2012 8:04 am    Post subject: Reply with quote
Geez...Robotprops is right; I always thought I had seen that design before, but I couldn't, for the life of me, remember where.
Thanks for re-firing my brain Confused
PostPosted: Tue Jan 17, 2012 4:16 pm    Post subject: Reply with quote
Very close indeed. Syd's is based off of Rich Coyle's though, which was made from a firing pin IIRC. I might have to go back and check Rich's build diary on his site. It also continues down into the gun much deeper. Still these would make great pre-made replacements if needed. I want to see pics of these spray nozzles tips too.
Robotprops
PostPosted: Tue Jan 17, 2012 4:34 pm    Post subject: Reply with quote
The hero would have utilized the firing pin as it was at the end of the bolt. But it's not outlandish to think that Sid would have used a spray nozzle to cast from.
I used one in a garage kit that I was trying to give life to.
You can make it out a bit in this one:
PostPosted: Tue Jan 17, 2012 7:26 pm    Post subject: Reply with quote
Gun is looking good so far as I can see in the pic. I'm sure, spray guns have different type and models of pins. Worth looking into it for sure!
Robotprops
PostPosted: Tue Jan 17, 2012 9:07 pm    Post subject: Reply with quote
Thanks Joberg. I actually did the build a year ago. WIP pics are on the thread.
You're right about the nozzles. There are huge varieties of them large and small and the greeblie in question looks just like one. I might pull the tip out of that blaster if I get time...
