Total Recall gun
Goto page Previous  1, 2
Ki-Djowac
PostPosted: Sun Nov 18, 2012 3:11 pm    Post subject: Reply with quote
So, we're there Very Happy
How i intend to display it once i made some room in my cabinet :
There you have it Very Happy
PostPosted: Mon Nov 19, 2012 7:40 am    Post subject: Reply with quote
A+ Ki-Djowac...but I think it's rather problematic to display it with a picture of Jessica; what to look at first? Shocked
Ki-Djowac
PostPosted: Mon Nov 19, 2012 9:56 am    Post subject: Reply with quote
True indeed Very Happy
Imagine the conversations :
Dude : 'Hey, that's just beautiful, amazing and kick ass dude'.
Me : Yeah, but what do you think of the gun ?
Wink
PostPosted: Mon Nov 19, 2012 7:12 pm    Post subject: Reply with quote
Ki-Djowac
PostPosted: Sun Dec 09, 2012 5:59 am    Post subject: Reply with quote
One last update :
After watching the Blu-Ray i noticed something else on the gun. Red safety dots. The Umarex Beretta doesn't have these.
Yeah, somehow, when you did a prop from a movie, you watch the movie differently then before Laughing
Anyways, here's my last adjustment :
I recommend using a size zero paint brush for painting the red dots and a 3mm drill for drilling the dent on one side. When looking very closely at the Umarex Beretta 90two you'll notice that there's a obvious dent on one side and a very light circular marking on where the dent should have been. This is the place to drill. The slide is metal so primer first and then i picked up a model paint ferrari red (n 34) from Revell.
And finally done :
PostPosted: Sun Dec 09, 2012 9:05 am    Post subject: Reply with quote
The devil is in the details and you certainly produced a kick-ass repro Ki-Djowac...very cool Cool
Ki-Djowac
PostPosted: Thu Dec 13, 2012 1:21 am    Post subject: Reply with quote
Thx for the compliment Joberg. Smile
Gonna start the run for these very soon.
Ki-Djowac
PostPosted: Tue Dec 25, 2012 4:08 pm    Post subject: Reply with quote
Allright y'all,
inspired by Bad Wolf over at RPF i got my own 6mm Beretta 90two springer gun.
As Bad Wolf pointed out, the two guns look indentical, but still there are small differences in measurements between the two which leaves a small gap between the front barrel slide and compensator itself.
I modified 2 pieces on the springer gun : i filed about 2mm on the front of the weaver rail and dremelled the trigger guard. On the front weaver rail mod i locked the barrel slide as if it was empty and used some masking tape to avoid damaging the plastic cilinder/barrel parts.
The other modifications were done to the compensator itself where it was drilled in front where the cilinder part right beneath the barrel would go on the inside and some dremmeling where the trigger guard would fit against the compensator.
First fit :
And some close ups of the 2 modifications on the springer :
After the trigger guard was dremelled, i used some sanding paper to try and match the factory finish of the plastic again. I used the following grids of sanding paper : 400 - 600 - 800 - 1000 - 1200 and finally a 15 micron 3M polishing paper. Anything higher then the 15 micron proved that the finish became too shiny compared to the rest of the gun.
Primer and sanding on the springer compensator is done and i'll start layering matt black soon Smile
PostPosted: Fri Dec 28, 2012 4:43 pm    Post subject: Reply with quote
Good stuff again Ki-Djowac... Cool
Ki-Djowac
PostPosted: Fri Dec 28, 2012 5:54 pm    Post subject: Reply with quote
Thx Joberg Very Happy
The springer comp is done, but i'm gonna finish my co2 comp first so i can do a comparison pic. Should be by the end of the weekend.
Ki-Djowac
PostPosted: Tue Jan 08, 2013 4:29 pm    Post subject: Reply with quote
Last but not least : a comparison between the 2 modified finished versions. Springer vs CO2 : Spot the difference Wink
That's it y'all. Done ! Smile
PostPosted: Tue Jan 08, 2013 6:27 pm    Post subject: Reply with quote
Very good transfo for sure! Did you shoot the weapons already and if so, how is the add-on reacts? (like in the film I suppose?)
gomcse
PostPosted: Wed Apr 02, 2014 6:20 pm    Post subject: Reply with quote
Wait! What happened??? Did you finish this? It's been almost 2 years!
Dave
resurrecting threads that died.
PostPosted: Wed Apr 02, 2014 6:53 pm    Post subject: Reply with quote
I believe he did... Confused
gomcse
PostPosted: Wed Apr 02, 2014 7:01 pm    Post subject: Reply with quote
But...is he selling them....?? What if we want one.....LOL.
Dave
PostPosted: Thu Apr 03, 2014 4:09 pm    Post subject: Reply with quote
I know he did a run on the RPF in the JY...you could also check there or sent him a PM here at Propsummit Wink
Page 2 of 2
