FS: BSG S1 Blaster
Matsuo
PostPosted: Wed Dec 12, 2012 1:03 pm    Post subject: FS: BSG S1 Blaster Reply with quote
Available on an extremely limited basis. $225 finished and painted.
Resin clamshell, built over working airsoft.
Airsoft is a highly modified HFC gas revolver. Resin shell is aluminum powder impregnated urethane resin. The grips have the wood grain finish cast in, no paint needed. The side switches are movable and cast in pewter.
Un finished kits of varying degrees of completion are available also, just ask.
Built, unpainted.
Clamshell kit.
I don't do "runs" as such, just letting you know these are available.
Thanks!
Matt
PostPosted: Wed Dec 12, 2012 6:20 pm    Post subject: Reply with quote
Always, a fan of you beautiful work (saw that cool gun on the RPF)...good luck with the sale:-)
AaronD82
PostPosted: Fri Dec 14, 2012 8:35 pm    Post subject: Reply with quote
How much for a clam shell kit?
Matsuo
PostPosted: Fri Dec 14, 2012 8:58 pm    Post subject: Reply with quote
$100 plus shipping.
M
Matsuo
PostPosted: Thu Dec 20, 2012 9:06 pm    Post subject: Reply with quote
Daddy Solo
PostPosted: Fri Dec 21, 2012 8:47 pm    Post subject: Reply with quote
free bump for an awesome piece! I have one and it is simply flawless.
jedeyenight
PostPosted: Wed Feb 20, 2013 12:28 pm    Post subject: Reply with quote
Hope I didn't miss out on these guys. Pm away.
Ozwepaie
PostPosted: Sun Mar 17, 2013 8:58 am    Post subject: Reply with quote
Giving Jedeye a hand w/ this one.
I'll post pix.
So if the build is preventing you from buying the kit? Don't let it.
I'm happy to do precision build-up, paint jobs, machined mods...etc.
And I'm very reasonable. I know a lot of you guys don't have tons of
tools, or may not possess the skill set to match your own standards.
Don't let that stand between you & quality toys.
Shoot me a PM
Oz
Que la Force soit avec toi
PostPosted: Sun Mar 17, 2013 9:34 am    Post subject: Reply with quote
Good to know Oz and thanks for the FYI
jedeyenight
PostPosted: Mon Mar 18, 2013 11:12 am    Post subject: Reply with quote
Yeah, Amazon sent me the wrong gun so Oz is machining me a custom barrel and milling the hammer. Thanks Man!
Bassnoir
PostPosted: Mon Mar 18, 2013 6:56 pm    Post subject: Reply with quote
..I have both an Offworld and Matt's version of the BSG Clamshell and there is no comparison...had I known about Matt I would have not bothered with the Offworld....no disrespect intended here it's just that Matt's work is spectacular...not taking advantage of this offer would be a crime.
Ki-Djowac
PostPosted: Fri Mar 29, 2013 4:20 pm    Post subject: Reply with quote
Received mine (finished version) today after a hassle free transaction with Matt. Definitely recommended as this is an awesome piece !
- Great balanced weathering
- very nice overall weight and feel : it feels heavy as a gun should
- Seeing the cilinder rotate after pulling the trigger is a definite bonus
- Overall an awesome quality prop !
PostPosted: Fri Mar 29, 2013 5:27 pm    Post subject: Reply with quote
Thanks Ki-Djowac for the revue...you cannot go wrong with Matsuo.
