Coyle M2019 Build instructions?
Lucian
PostPosted: Wed May 01, 2013 12:25 pm    Post subject: Coyle M2019 Build instructions? Reply with quote
I have a kit and I believe the complete name/version is:
CS&T All-Metal Worldcon (2010) Blade Runner M2019 CNC Blaster
But I have no instructions, are there any anywhere?
Thanks Smile
PostPosted: Wed May 01, 2013 1:20 pm    Post subject: Reply with quote
You should PM Racprops: Rich is your man for that
PostPosted: Wed May 01, 2013 1:44 pm    Post subject: Reply with quote
Here are the instructions:
These started with a special Kit run for a web site called propsummit:
http://s922.photobucket.com/albums/ad67/racprops/Propsummit%20SE%20Blade%20Runner%20kit%20instructions/
Please note there are many sub folders.
ALSO PLEASE Read all these instruction and check over you kit parts carefully, NOT all operations shown in these first instructions will be needed or used in the newer version of the kit and please NOTE the following instructions and used them on the newer kits.
Then follow upgrades and improvements:
Building the new ammo clip and housing;
http://s922.photobucket.com/albums/ad67/racprops/2011A%20Model/Building%20the%20new%20ammo%20clip/
Building the new side cover with hidden wire or not:
http://s922.photobucket.com/albums/ad67/racprops/Assambly%20Instructions%202011%20two%20part%20models/NEW%20Side%20cover%20Hidden%20wires/
Building the new trigger guard.
http://s922.photobucket.com/albums/ad67/racprops/Assambly%20Instructions%202011%20two%20part%20models/NEW%20Trigger%20Guard/
Last a couple of pages for special shipping that also helps builders:
http://s922.photobucket.com/albums/ad67/racprops/Final%20Assembly%20or%20Reassembly/
If you have any problems feel free to email me, and if you can include pictures of the problem.
Happy Building
Lucian
PostPosted: Thu May 02, 2013 3:36 pm    Post subject: Reply with quote
Thank you, Rich! This should keep me busy for awhile.
I'll PM if I run into any trouble and hope you are feeling better Smile
PostPosted: Thu May 02, 2013 4:47 pm    Post subject: Reply with quote
Lucian, we'd love to see pics of your build of course...so don't be shy to post and that way, if there's a difficult part to put together, Rich or others would be able to help you
