Building a full size vidphon
Goto page Previous  1, 2
PostPosted: Wed May 17, 2017 6:48 am    Post subject: Reply with quote
This frame is looking very good/sturdy...what kind of material are you going to use for the shell?
electronic_matt
PostPosted: Wed May 17, 2017 9:56 pm    Post subject: Reply with quote
I may try vacuum forming the sides and top part
PostPosted: Thu May 18, 2017 7:02 am    Post subject: Reply with quote
Quite the size to vacu-form...I'm wondering if they used fiberglass for the original?
kevdeo
PostPosted: Sun May 28, 2017 1:09 pm    Post subject: Reply with quote
Excellent work! That exterior shell seems like something youd want to fiberglass
youtube.com/user/kevdeovideo
instagram.com/kevdeo
GKvfx
PostPosted: Fri Jul 21, 2017 5:14 pm    Post subject: Reply with quote
The vacform machines they had access to were quite large. Having played with the real VidPhons, I can tell you they are styrene or ABS (I suspect styrene due to the aging that I saw. Some of them are beat to crap.)
My best guess is that the "panel" was vacformed flat and then cut out and heated as it was rolled around the frame, being tacked in place as they went.
Gene
PostPosted: Sat Jul 22, 2017 11:43 am    Post subject: Reply with quote
TFS Gene...ABS would make sense for sure.
Page 2 of 2
