Posted: Thu Oct 02, 2014 11:40 am Post subject: Last Real Blade Runner Bulldog Barrel |
OK Here is the last deal on a real rifled Blade Runner custom made 4.5 inch barrel.
It has never been fired but slightly used barrel that was once mounted on a Bulldog frame and then marked and drilled partly into the side wall to apox. .010 of the inner wall of the bore and bottom taped for the screws.
The mistake was I had not tightened it fully onto the frame and once I did it was then misaligned to the Steyr Receiver and the Ammo Housing as well.
So I could not use it on a real working firing weapon.
So I am offering it at a discount: $150.00 plus shipping.
Also you can still get the cylinder locking screw for $25.00 plus shipping (no shipping if ordered with the barrel.)
There are three ways this barrel can be used.
1) In a totally dummy model never to be fired. (Where being correctly tight will not matter.)
2) In a real firing model if you’re willing to use a slim to key it to the correct alinement.
3) There is also a slight possibility it might fit and align in a new Bulldog. (slim but real none the less)
