1/6 Scale Spinner Model
PostPosted: Tue Dec 23, 2014 10:10 pm    Post subject: Reply with quote
I kinda want to see a Military version of the spinner, with the big cannon and wheel pod guns, in green and some extra armor....just teasing you Rick Wink...or am I Very Happy
PostPosted: Sun Dec 28, 2014 4:01 pm    Post subject: Reply with quote
I hear you Andy, let's just go back to Syd's first Spinner design (the one with one M...F...K canon on top of the cockpit )
doppelganger01
PostPosted: Sat Jan 17, 2015 3:02 am    Post subject: Reply with quote
I have begun the printing of my G.I. Joe / Starsky and Hutch Spinner Project. So far, I have only done 3 parts of the bottom section. I am printing on a Projet 1500 printer, which uses a UV develop resin. The resolution is fair to good, depending on the part's orientation on the build platform. Part surfaces that are parallel to the resin tray develop without print lines. Angled and curvilinear surfaces, with respect to the platform, do show print lines at a resolution of 1024 x 768 on the XY and 0.004in. on the Z axis. For the most part this is sufficient and acceptable after I factor in material cost. I will, however, be doing a great deal of surface putty work and sanding. Due to the bounding box dimensions of this printer vs. the overall size of my model, it was necessary for me to divide up the entire car into printable sizes. I started with the bottom chassis by cutting it up into six sections with mating tabs. Once I have printed the sections for the bottom chassis, I will assemble, clean and prepare it as one complete sub-assembly piece that will later interlock with other consolidated sub-assembly parts. For now I only have the first three sections to show you. I apologize for the rough images. As I complete each of the planned sub-assemblies, I will take more care in documenting them.
www.pflagerkatsumata.com
www.ricklross.com
R.A.M.
PostPosted: Sat Jan 17, 2015 2:40 pm    Post subject: Reply with quote
Sweeeeeet!
RAM
Are you a replican? Or a replican't?
PostPosted: Sat Jan 17, 2015 3:48 pm    Post subject: Reply with quote
TFS the process with us Rick. Eager to see the rest Cool
PostPosted: Sat Jan 24, 2015 1:02 pm    Post subject: Reply with quote
This is a great project Rick. Looking forward to it evolving.
I know that large thin walled panels of 3D print have a tendency to warp or move out of shape sometimes due to temperature. Are you planning on putting any structure inside to help prevent twisting when it's all together. I suppose the limits of your bed size may help.
Are you planning on printing everything?
Colin
Ripley: What's it key on?
doppelganger01
PostPosted: Sat Jan 24, 2015 3:58 pm    Post subject: Reply with quote
Thank you.
Yes, you are correct about the warping issue. And I am governed by my build platform size, as well as, expense of resin. So, I have to strike a proper balance for each printed part. In the case of the 6 floor panels, the warping is not an issue. There are, however, some dimples and textures that I will have to putty over. I will assemble all printed parts for this spinner into about 5 or 6 sub-assemblies that I will clean, mold, and cast. These cast resin sub-assemblies will be designed in such a way as to interlock with one another and affixed to an internal framework that will allow me to suspend the finished model from the ceiling or wall in such a manner that it will be structurally sound and allow for electrical wiring for lights. That's the plan for now, at least.
I plan to print as many parts as I can for the pattern, supplementing with handmade elements when necessary. The final model will be composed of cast resin and vacuformed parts, though.
www.ricklross.com
PostPosted: Sat Jan 24, 2015 5:09 pm    Post subject: Reply with quote
Thanks for the detailed reply Rick.
That all makes perfect sense. By the sounds of it it's going to be an expensive project if you are printing, moulding and casting.
Colin
doppelganger01
PostPosted: Sun Jan 25, 2015 4:20 pm    Post subject: Reply with quote
Agreed. Even I think myself crazy for attempting this project, but I just want a large scale spinner in the room. Even if it takes me the whole year, or two, it will be worth it to me. This is one of a select few studio scale models for which I have a genuine passion.
Here are the printed parts for the bottom chassis panel sub-assembly, and what my budget will allow for now. As you can see, I have a lot of work ahead of me just for this one sub-assembly. I have begun filling imperfections and dimples with JB weld Kwik for now. I have ordered Smooth-on's new XTC-3D for 3D prints. They say it is good for removing print lines and is a self-leveling resin, which I will definitely need for the interior side of this panel. I will let you know how that goes. In the meantime, however, I need to finish two new and one resurrected PKD projects that are long overdue.
Rick
www.ricklross.com
PostPosted: Sun Jan 25, 2015 7:47 pm    Post subject: Reply with quote
O.k...I broke the chair (jumping up and down too hard ) yes! It's already looking good Rick.
TFS with us on that massive project Cool
Bendzhamin1967
PostPosted: Sun Jan 25, 2015 11:26 pm    Post subject: Reply with quote
fascinating! i only wish i was half as talented in the 3d printing area... my grounded spinner will have to be done the Old Skool way...
Bendzhamin1967
PostPosted: Sun Jan 25, 2015 11:30 pm    Post subject: Reply with quote
it says your photobucket is private.... did i miss the password or something???
doppelganger01
PostPosted: Mon Jan 26, 2015 5:49 pm    Post subject: Reply with quote
Thank you. At the rate I am going with the Projet printer, and the expense of resin, I probably would do better making mine the old fashioned way too. For some parts I will have to do that. I look forward to seeing your ground car finished. I know it will be excellent.
I just use photobucket for hosting images here and on the RPF. You can access them too on Flickr and Deviant Art.
https://www.flickr.com/photos/ricklross/
http://kipple-maker01.deviantart.com/gallery/
www.ricklross.com
PostPosted: Mon Jan 26, 2015 8:06 pm    Post subject: Reply with quote
Thanks for the links Rick
DaveG
PostPosted: Thu Feb 12, 2015 4:32 pm    Post subject: Reply with quote
Outstanding work Rick!
Dave
doppelganger01
PostPosted: Sun Mar 08, 2015 6:54 pm    Post subject: Reply with quote
Thank you.
I have assembled the bottom panel for molding. I still need to do some more clean-up on it, but its done for the most part. I will need to print a few separate detail parts for the centerline rear midsection. I lost the printed details in the parts during assembly of the six panel. I also prepped a couple of midsection side panels and the two rear propulsion vents. This will be a long drawn out project for me, since I cannot devote constant time and resources to it, but I will make as much progress as I can. Slow and steady wins the race best, sometimes.
www.ricklross.com
PostPosted: Mon Mar 09, 2015 6:06 pm    Post subject: Reply with quote
Beautiful work there Rick...impatient to see the next update Cool
PostPosted: Tue Mar 10, 2015 2:24 pm    Post subject: Reply with quote
Like joberg, looking forward to seeing this develop.
Looks like you've got a good surface finish on that Rick. Did it take a lot of sanding and filler priming?
Colin
doppelganger01
PostPosted: Thu Mar 12, 2015 1:33 am    Post subject: Reply with quote
Colin
Thank you. Actually it did take quite a while to achieve. I still need to clean it up a bit more, though. The Project 1500 does not produce the best printed parts consistently. It took some effort to fit the 6 panels together. And as you can see in the image, I lost some detail at the mid-center. I will print a separate detail part that I can glue onto this pattern to replace the missing details.
For the next round of prints, I will continue with the rear substructure parts. I hope to resume the printing by the end of the month.
Rick
www.ricklross.com
PostPosted: Thu Mar 12, 2015 4:08 pm    Post subject: Reply with quote
Are you going to put the figures inside?
Page 2 of 3
