Microma module
Deckard_0489
PostPosted: Mon Jun 06, 2016 5:36 pm    Post subject: Microma module Reply with quote
hi, the microma 3 buttons module is rare to find (only the internal parts I mean)? I saw that there is a Sekonda watch brand that should have the same module. thanks
PostPosted: Tue Jun 07, 2016 2:45 pm    Post subject: Reply with quote
Are you asking if the modules are hard to find?
They turn up on eBay from time to time. They're often between 150 and 200 $US (Yes, the modules alone). Sometimes - but rarely - much cheaper, I just picked up two fully working Micromas for only 89$US. You can get lucky...
Don't know about the Sekonda...
Deckard_0489
PostPosted: Sat Oct 29, 2016 11:14 am    Post subject: Reply with quote
Good evening everyone, I pick up back this thread to ask you one thing, those who have a microma blade runner type has ever noticed a defect which consists in skipping hours?? My watch for example when arrive to 19:59 then pass to 10:00.
Pierre990429
PostPosted: Sun Nov 06, 2016 5:43 am    Post subject: Reply with quote
Hi, that's a classical issue with those modules.
You need to push the RESET lever after having replaced the batteries.
Be sure to make electrical contact for 5-10 seconds.
Those modules are really touchy. I had the exact same issue but it went away after a correct "reset".
Even having the batteries out for 48h doesn't seem to be enough.
Verify that the hours advance normally afterwards, when you set the time, AND that you can set the date and the month. (sometimes the month setting can get skipped too, I mean you haven't the option to change it because of a bugged module - a good "reset" corrects this too)
