johnojodo Community Member
Posted: Mon Nov 13, 2017 4:30 pm Post subject: Template help |
Hi all
I'm starting to swap out parts on my printed blaster for steel/Ally bits
Was just wondering if any of you kind lot had any templates you could help me with. I'd like to make my own grip frame, bulldog receiver frame and bulldog grip. If anyone has ANY templates to aid me in this it would be a great help. I've used the search box here on the rpf, google and bing but turmed up blank
Thanks for any help
Ed[/img] |
Posted: Tue Nov 14, 2017 7:34 am Post subject: |
Eltee, veekthor should be off help johnjodo  |
Posted: Tue Nov 14, 2017 10:43 am Post subject: |
Thanks Joberg your a star |
Posted: Wed Nov 15, 2017 10:45 am Post subject: |
Anyone got there shooter stripped down and would be willing to trace round the bulldog grip frame parts for me? more than happy to pay
I can get the grip frame outer from my grips but id get the inner cuts wrong.
Or if someone could give me the measurement across the bottom most section of the bulldog grip plate and I'll try resizing pics |
djblingbling1 Community Member
Posted: Wed Nov 15, 2017 11:51 am Post subject: |
You want just the grip frame or the part around it?
Im using Offworld outer parts so they are a bit small, but I an trace my grip frame for you, scan it at work this weekend and send it to you. |
Posted: Wed Nov 15, 2017 12:00 pm Post subject: |
Thanks djblingbling1 but it's the .44 size I'm trying to build. Really appreciate the offer though
Its this part
https://www.gunpartscorp.com/products/322860
How thick it is would help too
And the part that surrounds it if at all possible  |
Posted: Wed Nov 15, 2017 4:21 pm Post subject: |
Your in luck...the grip frame is the same on the .38 and .44
Mines already trimmed if thats ok. |
DeckB26354 Community Member
Posted: Wed Nov 15, 2017 5:22 pm Post subject: |
PM sent |
Posted: Thu Nov 16, 2017 10:44 am Post subject: |
djblingbling1 wrote: | Your in luck...the grip frame is the same on the .38 and .44
If you wouldn't mind that would really help
You guys are great! |
Posted: Thu Nov 16, 2017 1:55 pm Post subject: |
djblingbling1 how thick is the bulldog grip frame?
I'll order some aluminium ready for cutting and sanding and getting wrong a few times  |
Posted: Thu Nov 16, 2017 3:03 pm Post subject: |
About 4mm without looking....Ill strip the gun down and measure and trace it tonight. |
Posted: Sat Nov 18, 2017 7:18 am Post subject: |
Thank you!
I'd guessed about 4mm then I can go 4, 4 and 4 for the bulldog frame if I build it as 3 sections sandwiched and hopefully welded |
Posted: Tue Nov 21, 2017 2:47 pm Post subject: |
DeckB26354
It arrived today, Your a star  |
Posted: Thu Nov 23, 2017 3:12 pm Post subject: |
Always a pleasure to assist.
Glad it arrived OK.  |
Posted: Sun Nov 26, 2017 11:02 am Post subject: |
Ok, I've got the pommel and two grip frames roughed out The roughing out was done with a pillar drill, Jigsaw and power file. (worked out the bulldog grip frame from the outer frame and some web pics)
Now its a case of modifying a 3d print of the bulldog receiver so I can make my own aluminium receiver (3 ply 4mm aluminium and some 18mm tube as a barrel mount, this will let me push fit my home brew steel barrel into the receiver) |
Posted: Tue Nov 28, 2017 1:30 pm Post subject: |
Anyone got the steyr receiver width to hand please? 30mm sound right? |
