Source of front trigger (edit 10/26 help with trigger shape)
djblingbling1
PostPosted: Fri Oct 20, 2017 7:10 pm    Post subject: Source of front trigger (edit 10/26 help with trigger shape) Reply with quote
I've been searching here, as well as online in general as to what the source was for the front trigger....The hole in it would need to be far back vs centered to work with the existing holes in the bulldog frame, so just wondering if it was ever decided what gun it came from?
PostPosted: Fri Oct 20, 2017 8:33 pm    Post subject: Reply with quote
I am pretty sure it was a Smith and Wessen pistol, but I might be wrong. I know I was told it was combat frame, but it isn't. It is for the regular pistol with the non slip grooves. Might be a .45 trigger too. I will dig into my stuff here soon, and see what I can find out. I know I have one left. Adam savage actually got my most accurate one, but I know the one I had looked more similar to the Bulldog trigger. Regardless, it needs to be cut down quite a bit before it can be used.
djblingbling1
PostPosted: Fri Oct 20, 2017 8:39 pm    Post subject: Reply with quote
Thanks for the reply, look forward to seeing what you dig up!
Is there any sort of cutting guide out there on what needs to be cut?
I guess I can see what it looks like fitting and always trim one up.
Ill look around at S&W parts online and see what I can find.
CKovach
PostPosted: Fri Oct 20, 2017 9:06 pm    Post subject: Reply with quote
Andy is correct; it's a S&W. IIRC, it is not caliber specific but I believe it's from the older vintage frames and may have been on several models. I have several remaining from my BR blaster fab days...just email me.
/C
PostPosted: Sun Oct 22, 2017 3:48 pm    Post subject: Reply with quote
Craig/CKovach is the man, and I would believe whatever he says. An honor as always to have him back on board, and not just lurking Wink
djblingbling1
PostPosted: Sun Oct 22, 2017 8:46 pm    Post subject: Reply with quote
It looks like a single action trigger....still no luck finding the exact models it came off.
veektohr
PostPosted: Mon Oct 23, 2017 4:27 pm    Post subject: Reply with quote
It's a K frame trigger, I believe. Just look for the serrated ones. They're super common on the used market.
djblingbling1
PostPosted: Mon Oct 23, 2017 4:42 pm    Post subject: Reply with quote
I was searching for K frame since I keep hearing old, but the K frame looks the same as all the newer ones as well...unless its totally custom cut and then the pin hole drilled for it.
veektohr
PostPosted: Mon Oct 23, 2017 6:36 pm    Post subject: Reply with quote
Yeah, it has to be modified.
djblingbling1
PostPosted: Mon Oct 23, 2017 6:44 pm    Post subject: Reply with quote
Just so we are on the same page, this?
[img]
http://propsummit.com/upload/3094/smith-wesson-k-frame-trigger-264-grooved-s-w-0d955.jpg
[/img]
and here is where it would need to be cut....lot of work...
veektohr
PostPosted: Mon Oct 23, 2017 7:07 pm    Post subject: Reply with quote
Cut-off wheel on a dremel, a hand file, a drill press... baby, you got a stew goin'.
Just the tip of the iceberg, honestly. The whole project is quite a bit of work.
djblingbling1
PostPosted: Mon Oct 23, 2017 7:12 pm    Post subject: Reply with quote
Lol, good point....all I know is triggers are usually pretty hardened steel..the revolver frame is too easy to work with...Ive had to re-bend it back in to place 2-3 times now from being dumb.
Found the trigger for $6 shipped on ebay so its on the way, which means another step closer!
djblingbling1
PostPosted: Thu Oct 26, 2017 4:28 pm    Post subject: Reply with quote
OK...got the trigger, got the shape pretty sure 90% or so, can finish with a hand file..BUT....I THINK I need to shave a bit off each side, as it hits the trigger bar from the bulldog trigger.
My pencil is pointing to the bar that's in the way...99% sure it needs to be slimmed for it but wanted to make sure as its easier to take metal away than add it!
PostPosted: Fri Oct 27, 2017 12:11 am    Post subject: Reply with quote
Yes you need to mill some of the metal off to allow for that latch to move.
Here is the shape of what needs to be removed.
PostPosted: Fri Oct 27, 2017 2:50 am    Post subject: Reply with quote
Here you go this will illustrate best:
