A few questions about using a real bulldog
djblingbling1
PostPosted: Sat Oct 21, 2017 11:12 pm    Post subject: A few questions about using a real bulldog Reply with quote
Apologies for making a second post with some hopefully not obvious questions!
More of needing a clarification on the first.
If using a real bulldog, or on the original prop they intended to fire blanks, so my guess is the hammer stays intact, but is bobbed? If that's the case does anyone have a photo of the aftermath of doing it, just for curiosity sake?
Also the shell ejector rod, It appears it is trimmed down under the side cover but I cannot tell...what needs to be done with this on the real gun?
Thanks for reading, im doing my best as a noobie here to read as much as I can and soak it all in, and search as best I can before asking.
Very Happy
PostPosted: Sun Oct 22, 2017 10:37 am    Post subject: Reply with quote
eltee is your man...send him a PM Wink
djblingbling1
PostPosted: Sun Oct 22, 2017 11:12 am    Post subject: Reply with quote
Sent him a PM! Very Happy
djblingbling1
PostPosted: Sun Oct 22, 2017 6:24 pm    Post subject: Reply with quote
In the meantime I figured out the hammer thing...I had a photo showing what I needed without realizing it...if I can ever get off work ill play around with it and post up pics in case anyone else ever has the same question.
DeckB26354
PostPosted: Mon Oct 23, 2017 4:52 am    Post subject: Reply with quote
Hello
Yes, you are correct. Hammer is "bobbed" and the ejector rod was filed down to be shorter in order to clear the casing. Filed down a little crudely, so a modification that was probably done while the gun was being put together.
djblingbling1
PostPosted: Mon Oct 23, 2017 4:45 pm    Post subject: Reply with quote
Figured out the hammer, I 3d printed a mock barrel just for fun and can see how the stock shell ejector wont clear anything...I think it needs to be cut here:
[/img][/quote]
PostPosted: Tue Oct 24, 2017 3:59 am    Post subject: Reply with quote
Make sure you have downloaded the pics of the Hero from Karl Tate here... http://propsummit.com/viewtopic.php?t=156
These will answer a lot of your questions if you haven't downloaded them yet.
djblingbling1
PostPosted: Tue Oct 24, 2017 8:39 am    Post subject: Reply with quote
Yes sir, those photos have been a lifesaver!
PostPosted: Wed Oct 25, 2017 5:51 am    Post subject: Reply with quote
how come the handle has been cut off like that?
PostPosted: Wed Oct 25, 2017 6:21 am    Post subject: Reply with quote
Was about to ask the same question Beast Confused
djblingbling1
PostPosted: Wed Oct 25, 2017 6:37 am    Post subject: Reply with quote
It was a police turn in that gets de-commissioned via chopping up.
Luckily for me the rear of the gun is so customized on the blaster it wont be an issue to weld up a bracket to hold the grip frame.
I paid $13 for it so its worth the extra effort.
PostPosted: Thu Oct 26, 2017 6:43 am    Post subject: Reply with quote
Bargain for sure and you'll be in for the extra effort Wink
