Template help
johnojodo
PostPosted: Mon Nov 13, 2017 4:30 pm    Post subject: Template help Reply with quote
Hi all
I'm starting to swap out parts on my printed blaster for steel/Ally bits
Was just wondering if any of you kind lot had any templates you could help me with. I'd like to make my own grip frame, bulldog receiver frame and bulldog grip. If anyone has ANY templates to aid me in this it would be a great help. I've used the search box here on the rpf, google and bing but turmed up blank
Thanks for any help
Ed[/img]
PostPosted: Tue Nov 14, 2017 7:34 am    Post subject: Reply with quote
Eltee, veekthor should be off help johnjodo Wink
johnojodo
PostPosted: Tue Nov 14, 2017 10:43 am    Post subject: Reply with quote
Thanks Joberg your a star
johnojodo
PostPosted: Wed Nov 15, 2017 10:45 am    Post subject: Reply with quote
Anyone got there shooter stripped down and would be willing to trace round the bulldog grip frame parts for me? more than happy to pay
I can get the grip frame outer from my grips but id get the inner cuts wrong.
Or if someone could give me the measurement across the bottom most section of the bulldog grip plate and I'll try resizing pics
djblingbling1
PostPosted: Wed Nov 15, 2017 11:51 am    Post subject: Reply with quote
You want just the grip frame or the part around it?
Im using Offworld outer parts so they are a bit small, but I an trace my grip frame for you, scan it at work this weekend and send it to you.
johnojodo
PostPosted: Wed Nov 15, 2017 12:00 pm    Post subject: Reply with quote
Thanks djblingbling1 but it's the .44 size I'm trying to build. Really appreciate the offer though
Its this part
https://www.gunpartscorp.com/products/322860
How thick it is would help too
And the part that surrounds it if at all possible Very Happy
djblingbling1
PostPosted: Wed Nov 15, 2017 4:21 pm    Post subject: Reply with quote
Your in luck...the grip frame is the same on the .38 and .44
Mines already trimmed if thats ok.
DeckB26354
PostPosted: Wed Nov 15, 2017 5:22 pm    Post subject: Reply with quote
PM sent
johnojodo
PostPosted: Thu Nov 16, 2017 10:44 am    Post subject: Reply with quote
If you wouldn't mind that would really help
You guys are great!
johnojodo
PostPosted: Thu Nov 16, 2017 1:55 pm    Post subject: Reply with quote
djblingbling1 how thick is the bulldog grip frame?
I'll order some aluminium ready for cutting and sanding and getting wrong a few times Very Happy
djblingbling1
PostPosted: Thu Nov 16, 2017 3:03 pm    Post subject: Reply with quote
About 4mm without looking....Ill strip the gun down and measure and trace it tonight.
johnojodo
PostPosted: Sat Nov 18, 2017 7:18 am    Post subject: Reply with quote
Thank you! Very Happy
I'd guessed about 4mm then I can go 4, 4 and 4 for the bulldog frame if I build it as 3 sections sandwiched and hopefully welded
johnojodo
PostPosted: Tue Nov 21, 2017 2:47 pm    Post subject: Reply with quote
 DeckB26354
It arrived today, Your a star Very Happy
DeckB26354
PostPosted: Thu Nov 23, 2017 3:12 pm    Post subject: Reply with quote
Always a pleasure to assist.
Glad it arrived OK.
johnojodo
PostPosted: Sun Nov 26, 2017 11:02 am    Post subject: Reply with quote
Ok, I've got the pommel and two grip frames roughed out The roughing out was done with a pillar drill, Jigsaw and power file. (worked out the bulldog grip frame from the outer frame and some web pics)
Now its a case of modifying a 3d print of the bulldog receiver so I can make my own aluminium receiver (3 ply 4mm aluminium and some 18mm tube as a barrel mount, this will let me push fit my home brew steel barrel into the receiver)
johnojodo
PostPosted: Tue Nov 28, 2017 1:30 pm    Post subject: Reply with quote
Anyone got the steyr receiver width to hand please? 30mm sound right?
