Blade Runner 2049...Substitute cigarette tin.
PostPosted: Wed Nov 15, 2017 6:14 pm    Post subject: Blade Runner 2049...Substitute cigarette tin. Reply with quote
Missed the boat on this one and it looks like it will be a red hot item for sometime to come so started thinking about a substitute that wont blow the budget.
After @Buch posted the pictures of the 100% accurate tin he had acquired,
I asked him if I could use them for a project and post them for others and he was more than happy to allow that so a big thanks to Anders.
Here are Buch`s pics cropped down. The pics are ready to be printed out now but if someone cando a little photoshop magic to the front face pic and straighten out
the little bit of lens distortion and then post it here, it will be even better. I found a picture of the inside of the lid online.
Found a great tin locally, still waiting on it. Thanks to Tuckanator for the original dimensions 117mm W x 70mm D x 15mm H
This tin is 5 mm less wide and 5 mm less deep than the original but is a great overall match and in a great condition to work with and only cost $6. Once the blu ray is
out I will start to make the tins overall look more accurate.
ADDITION....
SSB fixed up the main picture and its perfect, many thanks Mike.
PostPosted: Thu Nov 16, 2017 7:52 am    Post subject: Reply with quote
TFS Tim and Anders!
PostPosted: Thu Nov 16, 2017 1:23 pm    Post subject: Reply with quote
You're very welcome, Tim! Can't wait to see more!
PostPosted: Sun Nov 26, 2017 10:19 pm    Post subject: Reply with quote
Just a test print to see how it turned out. Very happy.
PostPosted: Mon Nov 27, 2017 7:38 am    Post subject: Reply with quote
It's looking very good; I would've rounded the corners to make it more vintage-like (that's my 2 cents Wink )...but all in all it fits the look
Fragment
PostPosted: Tue Nov 28, 2017 2:52 pm    Post subject: Kyriazi Freres Tin Reply with quote
I just noticed that the inside image shown for your graphic is very similar but says CAIRO EGYPT. Instead it should only say HAMBURG (at least I think so?). This can also be the difference between the Blue Neptun version and the written one but I am not sure.
Your method is exactly what I wanted to do but for a different type of kyriazi tin. Thanks for giving the heads up on dimensions of the Capstan. Your's is looking nice!
PostPosted: Tue Nov 28, 2017 8:55 pm    Post subject: Reply with quote
Its just a test print J and not even stuck on, will round it off and make it
more screen accurate when better pictures are available. The best bit about using prints is that I can age the label to exactly the same as the screen used.
PostPosted: Tue Nov 28, 2017 8:57 pm    Post subject: Re: Kyriazi Freres Tin Reply with quote
Good spotting, yes that`s not the correct inner label and it doesnt print up well anyway. Will be updating that pic soon.
PostPosted: Thu Jan 25, 2018 6:56 pm    Post subject: Reply with quote
Started final work on this and will post pictures once done. It was posted as an inspiration to others to get a replica for very little outlay. I think it will more than fulfil that intention.
