Yep, another Voight-Kampff project
Goto page Previous  1, 2
PostPosted: Thu Dec 07, 2017 7:45 am    Post subject: Reply with quote
Good research and mock-up Hellnback and thank you Colin for having re-posted Mark Stetson's pics (as you can see on the last one, the little fins are clearly visible at the bottom of the trench )
The bellows are actually resting on the side of the machine. The one piece vac-form housing is therefore higher than the sides...hence the difference in height that you saw on the blueprint.
Man, that prop is sooo difficult to do right Confused
Hellnbak
PostPosted: Thu Dec 07, 2017 1:09 pm    Post subject: Reply with quote
Colin,
All good points, but I have to disagree about the arm placement. To me it just doesn't work as showing the angle of the head resting in the trench, seems all wrong for that. And the lines projecting up and to the left would be unnecessary for that, to me they look like an indication of the arm in the raised position. But hey, you know what they say about opinions, and the point is moot anyhow Laughing
I've been messing with this thing, and here's how it's looking so far. Quite a mess, to be sure....
but somewhere in there some sort of Voight-Kampff is slowing emerging. I think.
Steve
Politicians are like diapers.....they both need to be changed often, and for the same reason
Hellnbak
PostPosted: Thu Dec 07, 2017 1:16 pm    Post subject: Reply with quote
Thanks, Joberg. Someday a video will emerge showing the actual building process of this beast, and all our questions will be answered. Right?
Yes, it's very difficult to build something right when nobody knows what right is for this thing Rolling Eyes
Hellnbak
PostPosted: Sat Dec 09, 2017 8:57 am    Post subject: Reply with quote
Had to take some time off from my project, furnace went out, and that's not a good thing to have happen when in Michigan. In December.
But I did make some progress on building some sort of model using the PropShop drawings. Not sure how useful it will be, none of the projected lines lined up, had to made a lot of semi-educated guesses. But this is what I ended up with....
And can someone tell me what this is in the indicated area?
PostPosted: Sat Dec 09, 2017 9:41 am    Post subject: Reply with quote
Looking good Hellnbak.
I think those lines are the projection of the six vertical fins. Just how far they stick out in plan view.
If that makes sense.
Colin
Ripley: What's it key on?
framed
PostPosted: Fri Dec 27, 2019 4:42 pm    Post subject: Reply with quote
Hi Hellnbak,
It's been 2 years now since your last post. I am quite interested how far you are now?
Regards,
Ray
always a pleasure
Page 2 of 2
