2001 Docking bay
PostPosted: Sun Mar 28, 2021 6:09 pm    Post subject: 2001 Docking bay Reply with quote
While I'm still thinking about the airlock scene (and build) I'm reproducing the original screen-used docking bay that was photographed for 2001 Italia.com
I've taken accurate measurements of the entrance and produced the face with its tricky sides, leading to the bay. Next, I'll draw the paneling and the details right on that and will have to search for the greeblies later.
Jens2133
PostPosted: Tue May 25, 2021 4:55 am    Post subject: Reply with quote
I am loving this already. Your build threads are very inspiring.
PostPosted: Fri Jun 25, 2021 9:29 am    Post subject: Reply with quote
Well, long time no post...it's done (grey to blend everything), next the white Wink
PostPosted: Mon Aug 02, 2021 12:19 pm    Post subject: Reply with quote
Continuing the build. Painted face and building of the bay itself.
Left wall insitu.
David3
PostPosted: Mon Aug 02, 2021 7:19 pm    Post subject: Reply with quote
Just awesome!!
PostPosted: Wed Aug 04, 2021 8:22 am    Post subject: Reply with quote
Thank you Sir Wink
David3
PostPosted: Wed Aug 04, 2021 6:41 pm    Post subject: Reply with quote
Just curious Joberg. Do you think both the Orion & Aries would fit in the one docking bay together?
There looks to be provision for them both in this concept artwork but bit of a tight squeeze.
PostPosted: Fri Aug 06, 2021 8:26 am    Post subject: Reply with quote
Yes, there were supposed to be there together. Since the Space Station is an "In-between" (Earth trip to Moon trip) it's logical that the Orion was the first transport from Earth to SS and then, from there, passenger would board the Aries-1B from SS to Moon.
Wink
David3
PostPosted: Fri Aug 06, 2021 6:28 pm    Post subject: Reply with quote
Yeah, makes good sense.
Although i would hope they give ample time between transfers to allow one to hang out for a bit at the bar in the Earthlight Room.
i'm sure that would be a curious experience Shocked
PostPosted: Fri Aug 13, 2021 11:11 am    Post subject: Reply with quote
Well, a few goodies: both sides are done and I'm building the floor.
David3
PostPosted: Fri Aug 13, 2021 6:16 pm    Post subject: Reply with quote
You must have been a watch maker in your last life!! Wink
That is some gorgeous work!
PostPosted: Sat Aug 14, 2021 9:37 am    Post subject: Reply with quote
Thanks I'm trying to get a Orion that would be in the same scale also Wink
David3
PostPosted: Sat Aug 14, 2021 7:37 pm    Post subject: Reply with quote
Fab!!!
So, what is the scale?
PostPosted: Sun Aug 15, 2021 12:01 pm    Post subject: Reply with quote
Well, since it's now known that the original model's face is 15" in circumference...and that, according to the website "planet3earth.co.uk the slot of the bay is: 230 feet wide
63 feet high
244 feet deep ...I don't know math that well; I'm sure someone figured it out alrealdy Wink
David3
PostPosted: Sun Aug 15, 2021 3:53 pm    Post subject: Reply with quote
Did you mean 15" in diameter ?
So that works out somewhere in the ballpark of 1/220 scale
I thought the Moebius Orion might be a fit but its 1/160
PostPosted: Thu Aug 19, 2021 7:25 pm    Post subject: Reply with quote
Yep, the Moebius one (as the original Airfix I have since...1973) are way too big for that 15"scale. Maybe a paper model could be the ticket.
David3
PostPosted: Thu Aug 19, 2021 10:49 pm    Post subject: Reply with quote
or a 3d print file that could be scaled to suit
btw - i see moebius is coming out with a 29" Orion soon
PostPosted: Mon Aug 23, 2021 9:00 am    Post subject: Reply with quote
Yes, a 3-D print would be the bomb. I'll check on Moebius site for the Orion. 29" is almost the size of the model you see in the Howard Johnson service desk Wink
David3
PostPosted: Mon Aug 23, 2021 8:55 pm    Post subject: Reply with quote
go to CultTVman's Hobbyshop on Facebook and scroll down to August 19
and also August 21 the IPMS Nats in Las Vegas video at around 2:00
PostPosted: Wed Aug 25, 2021 8:43 am    Post subject: Reply with quote
Thanks, just saw the vid; great news about the 2 scaled Orion.
I'll surely buy the large scale, but also the 1:350...could be right for my Docking Bay Wink
