Posted: Mon Apr 21, 2008 7:54 pm Post subject: Grips |
Somethings I have noticed about the Grips...
1-The Grips themselves only have the grip texture at the very fattest and flat surface on the grips. It is possible they had the texture throughout the one side of the grips and when carved down the texture was lost. I have seen some Acrylic in vintage lamps and coasters that was very similar in texture and color. They could have been a material that was found as is, and just carved down to make the final grips, with extras cast from them.
2-The hole in the back of the frame lines up with what we had previously thought was a screw hole in the front of the grip frame. The line is even parallel with the barrel and could have possibly been used as part of a mounting bracket, or just a way to run power to the electronics without being seen on screen. The same way the Umbrellas were powered.
3-If you look at Karl's Photos of the grips from the back side while it was on the counter, you can see the images of the person standing behind it's Tag. It works like a lense and is extremely clear except when being photographed up close with the flash, and or near the cracks at the top screw areas.
Just some food for thought
Mr_Creepy Community Member
Posted: Mon Apr 21, 2008 8:46 pm Post subject: |
For what it's worth, I saved a post by philipes from (maybe) around Sep 2006 about the grips--can't remember the thread
Used without direct permission, so I can remove the "post pic" if needed:
 _________________ - Brian (formerly ToothTech)
Posted: Tue Apr 22, 2008 1:32 am Post subject: Re: Grips |
andy wrote: |
3-If you look at Karl's Photos of the grips from the back side while it was on the counter, you can see the images of the person standing behind it's Tag. Andy |
You can? Where?!
Go right. Stop. Enhance fifty-seven to sixty eight.
Boop boop boop!
Chicka-chicka-chicka-chicka
Deet deet deet!
superjedi Community Member
Posted: Tue Apr 22, 2008 8:16 am Post subject: Re: Grips |
phase pistol wrote: |
You can? Where?!
Boop boop boop!
Deet deet deet!
Gimme a hard copy, right there.  _________________ I find your lack of faith disturbing. . . |
