Masao Community Member
Posted: Sat Dec 22, 2007 2:59 am Post subject: |
Warning! Missing parts!
For those attempting to build this, you will need to copy additional pages.
In the instructions you will find a thumbnail of the tires, this will help you replace the missing tire page. Blow it up to 8.5 x 11 and you will have your missing tire parts.
Wheelwell. One of the front wheelwells is missing so you will need to copy the existing wheelwell page twice.
A little photoshop work should be able to cleanup the tires.
Assemble as per instructions.
Hope this helps. |
Toombs Community Member
Posted: Tue Jan 01, 2008 12:27 am Post subject: |
I plan on making one with an interior when I have time. It will have templats to trace the windows out.
________
Healthy Relationship Advice Dicussion
Posted: Tue Jan 01, 2008 4:39 am Post subject: |
Thanks.
One nice thing about the paper models is they don't need to be made of paper!
Clear parts can be printed on transparency stock. A clear dome with clear lights is possible! |
Posted: Tue Jan 01, 2008 12:56 pm Post subject: |
Yes you could use the paper parts as patterns and make the hole thing out of styrene. The bubble wheel pods can be bought at the mall in those little gum and toy machines. You can cut one bubble in half to make the rear corners.
Ron
________
Vaporizer wholesaler
Posted: Tue Jan 01, 2008 10:11 pm Post subject: |
Hmmm, maybe, but can you print on styrene?? Transparency stock is made for printers. |
