Assembly instructions Off World blaster
delorean
PostPosted: Sat Mar 01, 2008 6:41 am    Post subject: Assembly instructions Off World blaster Reply with quote
I disassembled my blaster fast as I had good reasons. Assembly will probably just work fine but some copper screws are shorter than others. Is there assembly instructions floating around on propsummit to reassemble. After the gun is refinished I fear I might forget.
Anybody??
As Rutger would say in his native Dutch: " Ik heb dingen gezien die jullie niet kunnen geloven!"
Floris, a replicant in tights Smile
docatomic
PostPosted: Sat Mar 01, 2008 2:06 pm    Post subject: Reply with quote
When I disassembled mine, I labeled all the screws... If you let me know which screws you're talking about, I should be able to tell you where they go. (I say "should" because, in a few instances, I wrapped the screw in the paper label and taped it all up until I need them again -- so I might not be able to read the label until the time comes for re-assembly, in about a week.)
