Posted: Wed May 06, 2009 5:13 pm Post subject: |
This is one of the resin versions of Sid's most recent blaster build. From what I understand of the Sidkit blasters is they generally arrived already assembled and you had to disassemble them for painting. May be its the same with this version as well.
In any case the assembly isn't quite as complex as it appears at first glance, just make sure you remember where each screw goes. Use a diagram if you have to. Other than that most of the parts fit together fairly logically and its not all that hard to put together. I dismantled my Coyle a few times while giving it a repaint. _________________
