USCSS Nostromo - Discussion Thread
Goto page Previous  1, 2, 3 ... 13, 14, 15 ... 37, 38, 39  Next
PostPosted: Wed Sep 02, 2009 12:04 pm    Post subject: Reply with quote
Let me restate what I was saying too. I want a real technical piece of art with information and specs more than a graphic designer piece that will look cool. In the end it will look cooler as a result. Excellent work Space Jockey
Mark Sheppard
PostPosted: Wed Sep 02, 2009 4:53 pm    Post subject: Reply with quote
Yes, perfect in every way.
PostPosted: Thu Sep 03, 2009 3:14 pm    Post subject: Reply with quote
Same as andy, JT & joberg , it's PERFECT the way it is, LOVE IT !!!
(don't touch it !! Don't touch it !!!)
BRAVO Graham for this more than awesome work !
bizbazboz
PostPosted: Thu Sep 03, 2009 4:47 pm    Post subject: Reply with quote
i agree, no need for a background when the ship looks that good !!
PostPosted: Fri Sep 04, 2009 2:49 pm    Post subject: Reply with quote
Thanks for the comments guys, means alot.
Does anyone know who wrote this? I like it, it's pretty good technical stuff.
http://en.allexperts.com/e/n/no/nostromo_(alien).htm
Mark Sheppard
PostPosted: Fri Sep 04, 2009 3:09 pm    Post subject: Reply with quote
I have seen this exact same thing on several other websites. The interesting thing is that you can see the drive towers in the unpressurized part of the nostromo looking down from the windows of Brett and parkers engineering room.
The only mistake is it should read LOCKMART, not the literal "Lockeed martin Very Happy Very Happy
PostPosted: Fri Sep 04, 2009 3:17 pm    Post subject: Reply with quote
Yeah me too...I like the tech spec at the end, it sounds like one of the guys from 'The Big Bang Theory' wrote it, which would be fine by me...
It makes sense to use information that is already out there, including Ron Cobb's spec, rather than creating something entirely new as that'll confusion everyone. Needs a couple of amendments to make it consistant with the Aliens Tech Manual, but only real minor stuff.
Mark Sheppard
PostPosted: Fri Sep 04, 2009 6:22 pm    Post subject: Reply with quote
I guess that makes sense about parker telling ripley that they will need to drydock to fix certain things, given that that whole central reactor enclosure of the Nostromo is not pressurized. ..makes a lot of sense actually.
PostPosted: Wed Sep 09, 2009 10:32 am    Post subject: Reply with quote
This is where it's at right now; I won't be amending anymore until I receive comments back from the modelmaker.
I found too that LOCKMART is a shortened or slang term for Lockheed Martin.
Thanks,
-SJ
PostPosted: Wed Sep 09, 2009 11:41 am    Post subject: Reply with quote
Perfect
FenGiddel
PostPosted: Wed Sep 09, 2009 11:49 am    Post subject: Reply with quote
Looking good, looking p-r-e-t-t-y good!
You planning to show the crew lift deployed, with little crewmen waving? (Or maybe just a crewman, for scale...)
PostPosted: Wed Sep 09, 2009 12:08 pm    Post subject: Reply with quote
Lookin' clean and sharp: what you need/want in blue-prints
Monroville
PostPosted: Thu Sep 10, 2009 1:36 am    Post subject: No shuttles in front and rear views1 Reply with quote
Still keep in mind that neither shuttle can be seen in the bottom front and rear views.
ALIEN:REVISITED fan edit:
http://originaltrilogy.com/forum/topic.cfm/ALIEN-REVISITED-movie-edit/topic/10458/
PostPosted: Thu Sep 10, 2009 12:15 pm    Post subject: Re: No shuttles in front and rear views1 Reply with quote
Yeah, I haven’t shown both the Narcissus and Salmacis yet; probably no point in drafting it up until Martin’s had the opportunity to look at it.
beal
PostPosted: Mon Sep 14, 2009 9:25 pm    Post subject: Reply with quote
Beautiful work Space Jockey! Absolutely stunning
Mark Sheppard
PostPosted: Mon Sep 14, 2009 11:31 pm    Post subject: Reply with quote
That is right on! Beautiful man!!!!
PostPosted: Thu Sep 24, 2009 10:20 am    Post subject: Reply with quote
I learnt some interesting trivia on the Nostromo model this last week which I found interesting.
The full-size set was made first, before the models, which explains some of the discrepancies with the airlock and Ash's Observation Blister location (once the model was built, they probably found there wasn't enough room to show it around the front landing leg).
In fact, due to a lack of communication, a block of wood appeared clad in model parts with an Airfix B29 Superfortress front dome window stuck on to to represent Ash's observation blister. This block of wood also housed the airlock.
However, it was found that this had accidently been postioned covering up the hole for the front landing leg to connect to, so it had to be moved back to accomodate.
On the final movie, it was taken off altogether.
PostPosted: Thu Sep 24, 2009 10:30 am    Post subject: Reply with quote
As for the blueprints, I'm now in the process of trying to get them licensed. I figure that if I don't, they'll end up scanned and on ebay. I know I've already shown previews, but these have already ended up on a reference artwork page elsewhere along with countless other copyrighted artwork, and it bothers me that on the site there's an icon where you can click and turn it into a t-shirt or mug or something.
So we'll see how it goes - thanks for the patience.
I've also made some modifications to the engines and added the shuttlecraft to front and rear views.
-SJ
PostPosted: Thu Sep 24, 2009 11:24 am    Post subject: Reply with quote
Ehh gaad!! That's what I don't need to hear; appropriation of blood, sweat and tears (your work Space Jockey). I think the licencing approach is a good one...with the hope that your work will not end-up on EvilBay...unless you said so
FenGiddel
PostPosted: Thu Sep 24, 2009 5:32 pm    Post subject: Reply with quote
Space Jockey wrote:
...a block of wood appeared clad in model parts with an Airfix B29 Superfortress front dome window stuck on to to represent Ash's observation blister. This block of wood also housed the airlock...
That would be interesting to see. Whatever that is poised on the forward gear's doors in the film is difficult to make out...though most of it appears to be the "feet" for the airlock lift.
Page 14 of 39
