Gaff87 Community Member
Posted: Fri Oct 23, 2009 8:35 am Post subject: |
joberg wrote: | No offence taken Neil  |
Art Deckard Community Member
Posted: Sat Oct 24, 2009 5:54 pm Post subject: |
joberg wrote: | Yeah I know Neil...by the way, I should show you my collection of coffee cup made for left-handed people . My point is that even if you rotate the tile to move the square to the bottom left-hand side, it modifies the overall look of the design: FLLW made two molds; a left-hand side and a right-hand side as to create a mirror image You'll see that type of look in Ennis house. |
I'm sure FLW just did the rotation thing. If you look at the Ennis House tiles with the square at the bottom left there is a 'trough' running down the right hand side . On the tiles with the squre positioned in the bottom right, this trough has 'moved' to the top.
EDIT: Now I'm looking through my Ennis books and I think I may be seeing THREE slight variations of the tile! Sorry Joberg!
EDIT 2: My god, my replica tile isn't like the BR one. Joberg is right.
NOOOOOOO!
*Throws tile out of window* |
Posted: Sat Oct 24, 2009 8:48 pm Post subject: |
Told ye!  |
Posted: Sun Oct 25, 2009 8:37 am Post subject: |
The main problem with the tile is that making a mirror image of a design as complicated as the Ennis tile is basically making another tile altogether...and that sucks believe me! Yes Precinct: 3 designs in Ennis house: left/hand-right tiles+flat tile.
BR flat: left-hand tile+flat tile. |
Posted: Sun Oct 25, 2009 9:37 am Post subject: |
Well, i've learnt something new today.
I just need to look closer next time  |
Posted: Sun Oct 25, 2009 5:13 pm Post subject: |
joberg wrote: | The main problem with the tile is that making a mirror image of a design as complicated as the Ennis tile is basically making another tile altogether...and that sucks believe me! Yes Precinct: 3 designs in Ennis house: left/hand-right tiles+flat tile.
What threw me was the fact that there are a few instances in the Ennis House where the tiles have simply been rotated (on the exterior at least). |
Posted: Mon Oct 26, 2009 6:46 am Post subject: |
The major problem with Ennis, and it's not to devaluate FLLW's work, but my wishes will be with the new owner; with counteless restoration work, and sometimes the wrong placement of tiles (simply rotated) it is a very expensive house to maintain ($100,000 per year) not only because of earth-quakes, but because of the way the house was built originaly.
Very complex subject to talk about here...maybe its own topic (for lovers of FLLW's work, or budding architects) would be necessary  |
c0median
Posted: Sun Feb 07, 2010 11:01 am Post subject: |
http://www.kropserkel.com/BRtiles.htm
have a look at this site _________________ "I've seen things you wouldn't believe. Attack ships on fire off the shoulder of Orion. I watched C-beams glitter in the dark near the Tannhauser gate. All those moments will be lost in time, like tears, in rain. Time to die."
- Roy Batty |
Posted: Sun Feb 07, 2010 1:13 pm Post subject: |
Thanks cOmedian but it was posted before;beside, Scott Maple is sometimes making an appearance on Propsummit from time to time...the tile is also wrong: the deep groove you see at the right hand side of the tile should be on top (small square at the bottom left corner) and, strangely enough, if you see his other tiles (small square at the bottom right corner) the deep groove is at the top where it should be.
Just a reminder: the tile in Deckard's apt. are with the small square at the bottom left hand side. |
c0median
Posted: Sun Feb 07, 2010 2:00 pm Post subject: |
i should have took more notice so thanks for spotting them out for me _________________ "I've seen things you wouldn't believe. Attack ships on fire off the shoulder of Orion. I watched C-beams glitter in the dark near the Tannhauser gate. All those moments will be lost in time, like tears, in rain. Time to die."
- Roy Batty |
Posted: Mon Feb 08, 2010 7:23 am Post subject: |
You're welcome cOmedian  |
Posted: Wed Feb 10, 2010 7:11 pm Post subject: |
is it POSSIBLE it was done that way on purpose... to scoot around th FLW issues? All the other merchandise they crank out looks magnificent and alot of attention to detail...  |
Posted: Thu Feb 11, 2010 7:22 am Post subject: |
There's no way you could try (as many have tried before) to go around FLw's issues in terms of design; if it looks like/smells like and have the appearance of the original tile, it's the one and the same.
It's like trying to transform the Coca-Cola bottle by putting it upside down Let's get real here, if FLW wants to send a C&D to any maker of the tile, they can! |
Posted: Thu Feb 11, 2010 9:05 am Post subject: |
Yes... guess i was in a hurry to justify the error. In my OWN project i have struggled with the FLW issue and am assuming the BR liscense holders(?), but i am pushing onward.  |
Posted: Fri Feb 12, 2010 7:37 am Post subject: |
I don't think they'll go after one guy making a small set for a personal project...kind of killing a fly with a sledge-hammer  |
Division 6 Community Member
Posted: Sun Apr 04, 2010 7:43 am Post subject: |
Maybe a set...not a real hotel in Vegas (unless they ask permission to use the design?)...or the lawyers don't know its existance  |
Posted: Sun Apr 04, 2010 12:54 pm Post subject: |
I seem to recall another episode of one of the CSI's having the tile design on an elevator door.
Posted: Mon Apr 05, 2010 4:10 pm Post subject: |
The show is shot mainly in LA so it's just a set.
E... |
jameth Community Member
Posted: Mon Apr 12, 2010 3:17 pm Post subject: |
So is there any current supplier of Tiles????? |
